Home > General > Learn something new every day................
3528cc
United Kingdom 2008 Range Rover Autobiography 4.2 SC V8 Buckingham Blue
I was tying my boot laces this afternoon, and as I was doubled over the Range Rover started to open all the windows and sun roof Shocked as I was obviously pressing and holding the open button on the fob Rolling with laughter
I knew the car had total closure feature, but not a total opening feature Laughing
Just thought I'd mention it Wink Regards
Royston
2008 4.2 Supercharged Autobiography
1994 Classic Vogue SE
1999 Rover BRM
1987 Rover Vitesse Twin Plenum
Post #414405 19th Nov 2016 6:56pm
alistairh
I've just realised my 04 plate does it as wel..handy in the summer to vent the car prior to using it...did you know if you press the lock button once if the cars locked it lights up the cars interior and the approach lights under the mirrors....i was impressed Laughing
Post #414406 19th Nov 2016 7:12pm
one of the misfortunes of wearing tight jeans... Laughing Thumbs Up ... - .- -.
Post #414407 19th Nov 2016 7:30pm
JAYBOY
Rolling with laughter Rolling with laughter 2020 Porsche Panamera Turbo Hybrid (V FAST)
2018 JCW Mini Cooper
2018 Skoda VRS
Post #414409 19th Nov 2016 7:36pm
You should all stop being blokes and read the instruction manual....
It is rather boring though, weak plot and a rubbish ending....
RAVE is even worse.... Rolling with laughter Pete
Post #414411 19th Nov 2016 7:40pm
3528cc
I wouldn't care, but I have read the manual Laughing Regards
Royston
1999 Rover BRM
Post #414417 19th Nov 2016 8:16pm
Weejock
2002 Range Rover Vogue 4.4 V8 Epsom Green
Be warned of Total Open, Total Close and Follow You Home Lighting etc. They are all optional settings which can be programmed by the dealer or capable diagnostic tool like the IID.
I say be warned as mine was set for Total Open but not Total Close. Total Open opened everything, nice I thought when trying it for the first time but Total Close didn't work so had to go around and close all the windows before I proceeded to wash the motor off.
Unfortunately I only realised Total Open included the sunroof too when the bucket of water I was throwing over the roof to rinse off was in mid flight! Shocked
Luckily not much went inside...Total Close was programmed in 30 minutes later with the IID tool Laughing
You can specify which lights you use for Follow You Home Lighting so if you always park in a certain position at home you can either have headlights or reverse lights (or whichever lights you prefer) come on for xx minutes (headlights must be switched off after the ignition to activate it). I believe facelift vehicles you can change the timing of the lights via the info screen, earlier ones I don't think you can.
Probably the best programming option, if you don't need it, is to turn off the Easy Entry/Exit auto steering column adjustment just to save on wear and tear.
Post #414501 20th Nov 2016 11:57am
