Home > Technical (L322) > heating issue
alistairh
heating issue
Ok next wee job.my heating only seems to blow out warm air if its sitting at the lowest fan speed..try and turn up speed and the air goes lukewarm..tried bleeding the system and didn't help? Rear passenger blowers lukewarm as well...
Post #414286 18th Nov 2016 8:45pm
alistairh
Forgot to mention..i got an engine fault last week saying electric thermostat fault last occurrence plausibility...could it be related
Post #414292 18th Nov 2016 9:08pm
Electric thermostat fault will not affect the heating.. I would take off the plug on top of the thermostat housing, under the pipe that goes to the plenum at the front of the engine, the thermostats can leak coolant into the plug and corrode and then seep up the wire and into the engine ECU and wreck it (I know it sounds far fetched but it does happen) If it is leaking then it's a new thermostat job...
Heating is probably a faulty motor for the blend flap, an IID tool and some other diagnostic tools will read the fault and also interrogate the system to check what does and doesn't work... Thumbs Up Pete
Post #414315 18th Nov 2016 11:52pm
alistairh
I will check that tomorrow Thumbs Up I have an upgraded thermostat in its box ready to be fitted.if need be it can be installed as a priority! this is 2nd reason today for me to get an iid tool Laughing
Post #414325 19th Nov 2016 12:29am
