Home > Technical (L322) > Time from low to full ride height ?
phillips321
United Kingdom 2003 Range Rover HSE Td6 Galway Green
Hi guys,
I've got a second hand RR 2003 and it's slow to change ride height. Roughly how long should it take to go from access to normal, and then from normal to off road?
Sometimes it seems to take about a minute or more, what should I be checking?
I can't hear any leaks, can I do the ride height without the engine running to try and pinpoint a leak?
Thanks in advance
Post #412868 9th Nov 2016 10:35pm
alistairh
Mines takes about 10secs to get from access to normal height..then it can take between 30/45 secs to properly reach off road height...i find if I switch between different heights quickly it slows....must need time to build up pressure in the air reservoir
Post #412872 9th Nov 2016 10:59pm
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
25 secs 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #412922 10th Nov 2016 12:20pm
miggit
With the car in High mode turn off the engine and have a listen by each wheel.. if you've a leak then you'll hear it.. I suspect that it's just an older compressor.. but I will say that the ffrr (early ones) do take their time to finalise the height setting.. they take a few seconds to get within a few mm of the final height and then take forever adjusting it Evil or Very Mad They can't make their minds up Sad and it feels the need to tweek it for a minute.. all the time the light is flashing.. but their is Censored all detectable movement Thud Yesterday I couldn't spell Engineer... Today I are one!
Post #412924 10th Nov 2016 12:36pm
b348xyx
United Kingdom 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
I had this issue when I first got my Range, was the original compressor. Replaced and was a lot faster raising the car up after and less noisy.
Make sure you don't have any air leaks in the suspension though otherwise you will damaged a brand new compressor. 2003 Range Rover 4.4 Litre V8 - Adriatic blue
2003 Range Rover 4.4 Litre V8 -Maintenance History Click Here = http://www.fullfatrr.com/forum/topic39687.html
Post #412926 10th Nov 2016 12:48pm
Mulcher
England 2006 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
I think if your car was being too slow to change ride height you'd see the "Vehicle is raising slowly" message on the dash display. 2006MY 4.2 SC
BMW R1250 GSA Rallye TE
Triumph Tiger 1050 (sold)
1979 Pontiac Trans Am (sold)
Post #413329 13th Nov 2016 1:31am
miggit
^^ Shocked I've never seen that one ever.. reckon that must be a later software version.. I've only ever got EAS INACTIVE, and LOW MODE 35 MPH MAX Shocked and I was 40 miles away from home Sad That was a very, very long day Big Cry Yesterday I couldn't spell Engineer... Today I are one!
Post #413344 13th Nov 2016 8:40am
Stormin
2003 Range Rover HSE Td6 Epsom Green
There's also an air tank in the off/side sill, mine had a piece of wood stuck in it letting all the air out Three things in a blokes life his dog,his car and a Cornish pasty,nothing else matters.
2010 Range Rover Vogue SE Santorini Black, Arabica Aniline seats
Previous cars
1973 Mini 1000
1971 Hillman Avenger
1975 Chrysler Sunbeam
1981 Ford Cortina
1985 Volvo 340
1989 VW Golf
1989 Volvo 240
1991 Volvo 240
1991 Jaguar Soveriegn
1996 BMW 730
2003 Honda CRV
1999 Jaguar Soveriegn
2003 Range Rover HSE Epson Green with Sand trim.
Post #413524 14th Nov 2016 2:19pm
