![]() | Home > Maintenance & Mods (L322) > Vogue 2012 DRL question |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35511 ![]() ![]() |
if you mean the little drl lights in the headlight then only the gap iidtool will do that... ... - .- -.
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
I would suggest that you to find an Indy in your area.. the chances are they will be using the Gap IID Tool Pro.. cos that is about 4 times cheaper than the LR testbook.. and it will do more |
Mcfly309 Member Since: 24 Mar 2016 Location: North Lincolnshire-ish Posts: 76 ![]() ![]() ![]() |
Tried doing the same thing Stefan, when I first got mine. The following link may help explain about different country settings for DRL's.
Greggiii Member Since: 22 Sep 2017 Location: SW Posts: 5 ![]() ![]() ![]() |
Hi, old topic resurected.
any ccf [car configuration file] alterations will be vin locked so you will have to find an iidtool owner with a pro version.. ... - .- -.
and you know where to look for this guy?
