Home > Technical (L322) > Front Bumper Screw Bolts |
ohuntsman Member Since: 21 Mar 2016 Location: Surrey Posts: 337 |
On removing our front bumper to access the failing headlight washer (and a couple of tonnes of accumulated sand!!??) I have rounded the screw heads on a couple of the screw bolts that hold the bumper on - does anyone know where you can get replacements from?
10th Nov 2016 8:17pm |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 828 |
I think that you need DYG100640 and Dan from Duckworths should be able to supply them.
10th Nov 2016 8:53pm |
Top man - thank you |
10th Nov 2016 9:08pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Use this link to look up your car and get the part number for the correct bolts
10th Nov 2016 11:22pm |
forgot... if you is on SKY then you might want to read this first... there is a fix near the end
10th Nov 2016 11:24pm |
