![]() | Home > Off Topic - Other Cars > RAVE for Mercedes? Can anybody recomend something? |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
Hi all, Mercedes |
I've sort of got around that problem, I was trying to remove the swirl flaps, but just couldn't see the correct way of getting at them..... I think the only thing that didn't bolt on to the inlet manifold was the kitchen sink |
Zulu 10 Member Since: 28 Nov 2014 Location: Hampshire Posts: 88 ![]() ![]() |
I've bought a few Chinese clone Star C3 machines on Aliexpress but have just looked and the dreadful exchange rate means that with a hard disk they cost upwards of £200 at the moment.
It just went into limp mode, when I was towing, half way through a 200 mile trip... so I had to go on |
Charlyfarly Member Since: 26 Jun 2015 Location: Warwickshire Posts: 210 ![]() ![]() ![]() |
Maye I'm mad but I thought this was a FFRR forum |
...and I thought the heading of this sub-forum was "Off Topic - Other Cars". |
Touche If it ain't broken, fix it till it is. |
There is also another distinction to consider as well.... peeps on here actually know what they are talking about |
I've just downloaded this cos I'm now on win7 64 bit.. is it going to work with WIS? http://download.cnet.com/Windows-Virtual-P...51520.html Only I have very limited knowledge when it comes to PC's and I believe that the Virtual Player that came with the DVD fleabay bundle wont work on this PC as it's 64 bit ![]() ![]() Inventor of the 'Guide-o-Matic automatic wheel alignment tool' Former long term L322 owner, Up/Down graded to a Classic Tractor! |
Back on subject: a chum of mine has a 2.7l Mercedes-based camper which on infrequent occasions has a nasty habit of dropping into limp mode but with no MIL light illuminated. Unsure whether it's the same engine, but in his case the general wisdom seems to point to an EGR actuator solenoid, a faulty wiring loom relating to that solenoid, or a split vacuum pipe that the solenoid controls.
You should be able to download a 64 bit version of Virtual Player from vmware.com (I assume you're actually referring to VM Ware Player?) so your host is a 64 bit machine, but within that you can run either 32 or 64 bit guest machines. N.B. the reverse is hard work: running a 64 bit guest on a 32 bit host. The question is whether the VM guest machine file that arrived on the DVD can be run on either type of host - somehow I doubt it - instinctively I would expect there to have to be different versions of the guest file for 32 and 64 bit versions. (What I mean by that is that the guest in both cases would be 32 bit, but it would be contained in a different format depending whether the host is 32 or 64 bit oriented) Have you checked to see whether there are two versions are on the DVD? If none of this works then somewhere I've got an old known-good version of WIS that I no longer use which I'll drop in the post to you. That said trying to run anything on Vista is a game in itself: if you have no other reason for staying on Vista then you might be better reverting the machine to XP SP3 or converting to Ubuntu Linux cos that can run VMWare or Virtual Box far faster. |
