Home > Technical (L322) > Torque convertor ( supplier question) |
Rewmer Member Since: 14 Jan 2013 Location: Essex Posts: 142 |
Ive accepted that I need mine replacing - rev fluctuation, cattle grid effect etc and Ive been looking around a various places. J Pat and Sussex autos seem to be the favorites. But then i came across this ad in ebay
6th Nov 2016 5:01pm |
davidsmith1307 Member Since: 05 Mar 2015 Location: Hull Posts: 52 |
Worth asking RRPhil on here! |
6th Nov 2016 5:19pm |
Weejock Member Since: 30 Dec 2011 Location: UK Posts: 417 |
Can't really see the point in paying another £200 on top of the price I paid for mine from Sussex Auto for extra lifespan given the lifespan of my original was 100k+ miles and even then wasn't worn out (replaced as I took the gearbox off for another issue). It's likely my gearbox will need a rebuild before the replacement torque converter wears out.
6th Nov 2016 6:12pm |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 960 |
I agree that it would be very interesting to hear from anyone who’s tried one of these converters.
7th Nov 2016 12:03am |
ohuntsman Member Since: 21 Mar 2016 Location: Surrey Posts: 337 |
It seems Doug also repairs & sells all Tefal Activfry machines, does it make me a bad person that all I can see is a torque converter!!!
9th Nov 2016 11:59pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
I had one of those... I got 25 miles out of it before it destroyed it's self and my gearbox too
10th Nov 2016 12:05am |
Oh and another lesson learnt, you can't just fit a new / recon converter... only you start playing with the gearbox it really needs to be stripped and cleaned if nothing else, cos your worn out converter will have dumped a lot of grinding past in to the rest of the box.... it will sit there forever until you do something like change the oil... then it gets softened up and goes on a wrecking spree Yesterday I couldn't spell Engineer... Today I are one!
10th Nov 2016 12:14am |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
Do you have the TD6 and if so was the valve block checked before fitting the carbon fibre TC, just out of interest ? |
10th Nov 2016 1:42am |
First time the gearbox was power flushed.... second time the whole box was stripped and cleaned, and the valves were replaced with Sonnax upgrades... should have been done first time around
10th Nov 2016 10:22am |
So when the carbon fibre TC failed, was that the first time before the strip down and new sonnax valves? |
10th Nov 2016 7:46pm |
Proper one it is then. Diint think about checking out the other items for sale. Never would have put TCs and fryers in the same service supply area 🙀 No7 - 2003 V8 Vogue |
10th Nov 2016 8:04pm |
err not carbon fibre..Kevlar....
10th Nov 2016 8:20pm |
Sorry kevlar, I think the main killer is the valve body wear and then it seems common to replace / repair everything except the root cause which is the valve body and then in what can be a very short time, failure again caused by the lack of pressure to the LUC.
10th Nov 2016 10:30pm |
Not so sure that the ZF suffers in quite the same way, being built by the Germans who care about quality, rather than the French who care about dinner But I still reckon that if the TCC is fubar'd then it's a good idea to have the rest of the gearbox checked and cleaned if nothing else.. after all you've already paid to remove the box, it don't take that much longer to strip it and give it a wash. What you have to bare in mind is there will be a lot of crap, in the form of worn friction material, that will have come out of the TCC... If any is left in the gearbox then it will shorten the life of it.. I'm not saying just book it in for a rebuild, it might not need it, but have it properly cleaned and inspected before you make that decision.. If you have a good gearbox centre then they should be happy to do that, I know that STA Aylesbury will do that. When they got mine all apart they could have said it was knackered, but it wasn't, as it was 22k old, but it did need a really good clean as there was tons of swarf from the TCC going tits up Yesterday I couldn't spell Engineer... Today I are one!
10th Nov 2016 10:53pm |
