Home > Maintenance & Mods (L322) > Missing spring/cog function on passenger cup holder, see pic
phillips321
United Kingdom 2003 Range Rover HSE Td6 Galway Green
Hi guys,
My passenger side cup holder is missing the spring function so it's not possible to get it out.
As i don't have the bit it's difficult to know what's missing and what i need to order. I guess it's a wound spring on a cog?
Does anyone know where i could get a replacement part?
Many thanks
Post #412338 6th Nov 2016 9:08am
ia this any help,
http://www.fullfatrr.com/forum/topic32017.html ... - .- -.
Post #412342 6th Nov 2016 9:39am
phillips321
Ah yes that does help a bit. So the cog prevents the spring from firing the cup holder out at a million miles an hour, sadly i also have no spring!
So i guess i need both the spring and the cog parts. Any ideas?
Post #412358 6th Nov 2016 12:14pm
Unfortunately you can't buy bits for it, you have to buy the whole thing, around £100 IIRC.... Pete
Post #412373 6th Nov 2016 2:27pm
You could do this for a £3 fix.... And according to Johnboy it has bonuses attached...!!! Rolling with laughter
johnboyairey wrote:
my spring broke. so I drilled a small hole in the dimple, and fitted a £3 black ball shaped cupboard knob to it, from B+Q
So, now my missus gets to pull out my knob every time I buy her a Costa coffee.
 Pete
Post #412375 6th Nov 2016 2:30pm
Weegie
It was £63 from Dan @Duckworths. May have gone up a little. John
GAP iiD BT
Post #412378 6th Nov 2016 3:48pm
doclees
United States 2004 Range Rover HSE 4.4 V8 Java Black
I fixed mine with a post on the tray and metal. It just pops out to grab it and pull the rest but I can't spend $100 on a crap piece of plastic.
Post #412734 9th Nov 2016 7:12am
Macca
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
I did exactly the same as 'Johnboyairey' Thumbs Up but alas not the same result.......by the wife that is Wink
Low cost fix to be fair! D3 TDV6 SE 2006
FFRR TD6 Vogue SE Overfinch 2006
RRS TDV6 HSE 2007
FFRR 4.4 TDV8 Overfinch 2012
Post #412840 9th Nov 2016 7:37pm
