Home > Maintenance & Mods (L322) > Quick oil change gone wrong
jakebullet64
United Kingdom 2003 Range Rover Vogue 4.4 V8 Santorini Black
Big Cry
ok. What should be a 30 min / £50 job has become a nightmare.
The sump plug was dry but just span round instead of coming undone.
It eventually came off and so did part of the neck.
a new sump plate is 250 quid.
to get me back in the road the options as I can see are
1) put a bolt through with copper washers either side
2) chemical metal the hole
3) weld the hole up
what's the consensus?
cheers
jake
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  2003 Range Rover Vogue 4.4 on Gas
1961 88" 2.25 diesel - George
Gone - 1997 3.9 V8i Discovery - Burt
Post #412253 5th Nov 2016 5:01pm
Oops.
Not sure that's fixable. If you can weld it up it would be the most permenant solution. Looking at it I'm not sure you have enough lip to make a seal with washers. There is nothing that can't be fixed with a hammer😜😜
Post #412256 5th Nov 2016 5:11pm
jakebullet64
Hi Nm.
Thanks for your quick reply.
Yea. If it was just the thread a bolt might do but with this it'll be wonky. Good point.
anyone in the west mids / Staffordshire area able to tig this for me.
Shane a hammer won't fix it.
cheers
Jake 2003 Range Rover Vogue 4.4 on Gas
Post #412257 5th Nov 2016 5:16pm
cowman
United Kingdom 2005 Range Rover Vogue SE Td6 Adriatic Blue
there is a bloke at shenstone who mends alloys and casings he would do it.
Post #412258 5th Nov 2016 5:20pm
builder1966
England 2004 Range Rover Vogue Td6 Adriatic Blue
try http://www.tjreconstruction.co.uk/ hope you get sorted
Post #412259 5th Nov 2016 5:23pm
cowman
yes that is the place very good bloke
Post #412267 5th Nov 2016 6:24pm
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
I've just discovered that my sump plug was held in with silicone sealant - not good. So when I loosened it to drop the oil then tried to tighten it I realised why the sealant was there.
So I emailed a few breakers on eBay and I had one delivered for £50 in 2 days, it was as good as new.
So I would email a couple of breakers on eBay if I was you and replace it with a used item.
I was going to buy a kit to enlarge to hole and then tap a thread into it and use the sump plugs supplied, but I was afraid my cack handedness would get in the way and I'd have to buy a replacement anyway.
It's here if you want it and all you have to do is pay for the postage and buy the sump plug repair kit.
PM me if you want it. ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #412282 5th Nov 2016 8:33pm
johnboyairey
Yes, get on eBay, I think you can use the x5 lower sump too. just ask for overnight courier.
I bought a whole sump for £100, so be prepared to have to buy the whole thing. The upper sump is needed (unique) on the l322 engine, so sell that on.
Obviously, just take off the lower, and replace it.
Post #412283 5th Nov 2016 8:53pm
UK Marine
I think I was lucky, I asked for and did receive just the lower sump pan. As I've said my old one is here if you fancy tapping it out and putting in a slightly larger sump plug.
Regards ______________________________
Simon
Post #412294 5th Nov 2016 10:10pm
rangie47
get on the phone to these guys Monday morning ,
there right by you and may have 1 available Thumbs Up
http://www.equicar.co.uk/ 2007 tdv8 se ,stornaway grey
Post #412321 6th Nov 2016 1:07am
Once you get it fixed fit one of these to avoid the problem reoccurring
http://www.ebay.com.au/itm/NEW-EZ-OIL-DRAI...SwstxU5y44
then an oil change will be a quick and easy job at last Thumbs Up 2008 MY Supercharged
Post #412325 6th Nov 2016 1:43am
