Home > Technical (L322) > Air Con
SHasson1690
United Kingdom 2002 Range Rover Vogue 4.4 V8 Giverny Green
Air Con
Hi recently had my RR air con charged. System found to be OK ie no leaks,
Problem is temperature not blowing cold air, when turning on air con , engine revs up slightly, but no cold air .
Anyone have a solution ?? RR is 02 plate L322
Thanks in advance
Post #412245 5th Nov 2016 2:56pm
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Have you moved the wheel in centre of dash?
Post #412248 5th Nov 2016 3:12pm
SHasson1690
sorry, move the steering wheel??
Post #412250 5th Nov 2016 3:33pm
The little thumb wheel under the has are warning switch. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #412254 5th Nov 2016 4:01pm
