Home > Technical (L322) > Strange "Pwarp" noise from brakes |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6372 |
what circumstances do you get the noise? Is it when manoeuvering about at low speeds? Discovery 4 HSE
22nd Mar 2009 10:21pm |
jonny142 Member Since: 29 Oct 2008 Location: Sheffield Posts: 28 |
Hi RR, It usually happens when braking during normal driving conditions, and is intermittant Cheers 4.4 V8 Vogue Adriatic - Cream leather |
23rd Mar 2009 2:14pm |
I get that sometimes as well , i just put it down to the pads closing against the Disc's thats basically all it is , wouldn't worry to much about it......... |
23rd Mar 2009 2:20pm |
Someone has suggested "anti squeel sheilds" never heard of them myself 4.4 V8 Vogue Adriatic - Cream leather |
23rd Mar 2009 2:24pm |
Heard of "shields" on your Family Fords,Vauxhalls, and like but not on the FFRR.
23rd Mar 2009 2:30pm |
dantheman Member Since: 02 Feb 2009 Location: North: Lancs Posts: 477 |
Try taking your pads out, and coating the back (metal side) of them in copperslip - a sort of high temperature anti-corrosion compound - or grease which is commonly used in this application. Just make sure you don't paint it onto the friction linings... Hope this helps, Dan. |
23rd Mar 2009 5:24pm |
Dan if your brakes squeal, what is that a symptom of and how can it be remedied? My front ones squeal now and then at low speed in traffic. Discovery 4 HSE
23rd Mar 2009 6:54pm |
RRUK - Remedy wise, although brake squeal can be more of an annoyance than a safety issue there are several possible fixes:
24th Mar 2009 1:48am |
