Home > Technical (L322) > lights dimming!
alistairh
lights dimming!
Finally got the chance to take the fatty out for its first proper run since I bought it tonight..i have now noticed when I select drive or reverse the lights and interior lighting slighty dims and the car will rev at the very same time? I got the meter out and batteries 11.6 and 14.1 with the engine running..could it be the batterie affecting this? Apart from that I've fell in love with the big brute.. Pcv valves getting replaced in Saturday so I'm going to fit a new batterie at the same time and hopefully rectify this issue....
Post #411754 1st Nov 2016 7:50pm
Stacker
United Kingdom 2003 Range Rover HSE Td6 Adriatic Blue
My first checks would be the battery and alternator.
Really tired at the moment, but I did have a problem on my P38 where the lights would 'fluctuate' and constantly dim up and down. Turns out the rectifier was knackered on the alternator, £20 and half hour of my time and it was fixed. Not sure if your problem is similar but at least you know for the future Wink
Post #411818 2nd Nov 2016 2:28am
alistairh
Thanks for the heads up.. Thumbs Up Will check that out first...
Post #411832 2nd Nov 2016 9:43am
Lukie
2002 Range Rover Vogue 4.4 V8 Zambezi Silver
P38 alternator maybe cheap and easy to get to but l322 alternator will be a far bigger price
Post #411835 2nd Nov 2016 9:46am
