Home > Technical (L322) > driveline oils- transfer box and diffs
tommac22
United Kingdom 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
Hiall, wondered if anyone knows which oils are needed for the transfer box and diffs on a 2003 4.4? our defender uses good old ep90- but i suspect the FFRR requires something more exotic?
Thanks in advance!
Post #41161 6th Dec 2010 4:30pm
You will find the specifications here
Post #41163 6th Dec 2010 4:38pm
tommac22
superb, thank you, just what i was looking for!
Post #41166 6th Dec 2010 4:54pm
dan_uk_1984
Tables are NO fun!
http://www.fullfatrr.com/wiki/Recommended_Lubricants
Post #41172 6th Dec 2010 6:06pm
speedymarktd6
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
if u go to the dealer you need 3 litrres of diff oil as the rear uses a litre and the front is about 1.4 litres and the t/fer box is about a litre and a bit the cost of the diff oil is roughly £10 a litre and the t/fer box oil about the same but its different oil so get the correct stuff for yours Thumbs Up onto no6 Range Rover
Everyone needs a hobby
Post #41482 8th Dec 2010 7:45pm
