![]() | Home > Technical (L322) > Key won't turn in ignition fix 2002-2005 |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8405 ![]() ![]() ![]() |
This has been an ongoing problem for some time, the key goes in the ignition but the steering lock doesn't go off so it won't let you turn the key to start the engine, the "get you home" fix was to remove and insert fuse 18 and the system resets, this works if the lock is stuck in the off position, if it sticks in the locked position you've had it, it's a new column as JLR don't sell bits... This runs into thousands...
builder1966 Member Since: 23 Aug 2016 Location: ashingdon Posts: 299 ![]() ![]() ![]() |
well done pete brave man taking that lot apart forsure |
Great work Pete |
Thanks chaps..
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 ![]() ![]() ![]() |
Brave lad pete. |
MR GLOVER Member Since: 03 Jan 2015 Location: grimsby Posts: 605 ![]() ![]() ![]() |
think you should open a garage pete |
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 ![]() ![]() ![]() |
Lukie Member Since: 27 Sep 2016 Location: Liverpool Posts: 433 ![]() ![]() |
could you not just remove the locking pin (blue end) leave the motor in place ? |
Thanks chaps, someone had to do it.... It's a fairly simple system and I've searched for spares but apart from the magnet there is nothing out there, Johnson make the motor but it's not listed on their website, Kuhnke make the solenoid but won't sell them. |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
Does anyone know if they are common to any BMW models... it could be a cheaper source... especially if S/H... they don't seam to carry the Range Rover mark up |
I searched all the BMW models around that era and all their ELV's are different... Sods law...... Pete
They are all similar but different, even between the BMW's... Pete
Gits |
