Home > Maintenance & Mods (L322) > New Trolley Jack
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
New Trolley Jack
So I needed to fit my new wheels end of last week only to find my beloved son had messed with toy trolley jack and broke it (technically drained it of fluid and lost the plug..!)
So I need a new one. would something like this be any good and would I be able to lift the front or rear or one side with the attached bar..?
If not, should I just go with something like this
Thanks
(ps I needed up having a nightmare changing the four wheels - it took me over an hour...! There must be an easy way to jack the car up without having to go higher than fully extended airbags.?) Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #411488 30th Oct 2016 10:49pm
Stacker
United Kingdom 2003 Range Rover HSE Td6 Adriatic Blue
Don't people say the Mercedes Sprinter bottle jack is perfect for the L322?
I need to get a proper jack mine always drops when the FF is on it Evil or Very Mad
Post #411494 30th Oct 2016 11:18pm
I'm interested too as my trolley jack is on the way out (leaking fluid) and it's almost winter wheels (& tyres) time
Ash - why would you go for a low profile one ? I would have thought a high reach one would be better ?
Stacker - The sprinter jack could be stored in the boot - but a trolley jack is quicker if you're at home and keeping it in the garage Thumbs Up
Post #411496 30th Oct 2016 11:26pm
Jambo
United Kingdom 2012 Range Rover Westminster TDV8 Santorini Black
This is what I've used for my D3 and works a treat (not sure I can post direct link to Machine Mart website?)....
Clarke CTJ3000G - 3 Tonne Professional Garage Jack
Cost is currently �107.98 inc VAT. This is 520mm max lift height which you'll need to get the FFRR off the ground!
If I'm changing all 4 wheels I have a pair of axle stands so I can jack up and change both fronts then both backs - just be sure to chock the wheels!
Others may have more relevant info for FFRR.
Hope this helps.
Regards,
James.
Post #411497 30th Oct 2016 11:27pm
�58 on eBay Thumbs Up
I need to check the minimum height vs our Mini, but one of those could be finding it's way into my garage Thumbs Up
Post #411499 30th Oct 2016 11:32pm
Oh well - I just bought one - Jack Daniels & eBay - not a good mix Embarassed
Post #411509 30th Oct 2016 11:48pm
Strider
England 2007 Range Rover Vogue SE 4.2 SC V8 Zermatt Silver
Clarke CTJ3000G - 3 Tonne Professional Garage Jack Thumbs Up
This is the one I bought this year for my FF when working on it at home, I also bought a circular jacking pad to avoid marking the jacked areas.
I leave the suspension in standard setting with the drivers door open with of course usual precautions, wheel chocks / axle stands / hand brake on /drive in park pos'n.
I have used it to remove all 4 wheels for various jobs, it has plenty of lift and easily got the front wheels off the ground (locating on front rectangular recess behind front m/flap).
For the rear wheels I locate on the lower suspension arm as close to the hub as possible.
Post #411510 30th Oct 2016 11:52pm
Sounds like my JD inspired purchase may be OK Thumbs Up
What is one of those ? One of the BMW hockey pucks ?
Post #411511 31st Oct 2016 12:00am
builder1966
England 2004 Range Rover Vogue Td6 Adriatic Blue
i have the Clarke CTJ3000QL 3 Tonne Quick Lift Trolley jack from machine mart great price works well
Post #411520 31st Oct 2016 4:34am
classic Laughing ... - .- -.
Post #411529 31st Oct 2016 9:00am
Big Boy R44ROV
The Clarke 3 Tonne professional jack and two pairs of 6 tonne axle stands works for me. Thumbs Up being a safety consultant, I err on the side of caution !! Tony
You're always in the Censored ........it's just the depth that varies
2014 L494 5.0 S/C AB Silver
2014 L494 3.0 HSE in Chilli
2014 SL63 AMG White
Gone:
2011 5.0 L322 White (Stolen)
07 4.2 SC in silver.
06 4.2 SC in black RSE
RRS 4.2 SC in Black RSE
52 4.4 Vogue in silver
04 Mercedes CLK 320 Conv
03 4.0 V8 ES Disco in Silver
00 TD5 90 County
98 4.6 HSE in Epsom x3
97 3.9ES Disco
93 L 4.2 LSE in black
too many classics to mention !
Post #411531 31st Oct 2016 9:08am
ndg
United Kingdom 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
I wanted to get the car up high to do the suspension. 520mm lift is barely enough on the rear of the truck, so i bought a high lift Weber second hand.
http://www.ebay.co.uk/itm/162250193699
It's so nice using a quality jack that's easily capable of the job. It is massive though, so think about where to store it! I have mine stored under some long shelves the end. I bought a pair of extra two axle stands at the same time for �35.
Post #411533 31st Oct 2016 9:15am
ndg
Here it is with my old 1.5ton alloy racing jack.
Post #411534 31st Oct 2016 9:18am
comports
Thanks all
The reason for the low profile one is because I have a CLK as well and its quite low... I struggle with my current one to get under the side skirts (no jokes required at this point) hence the low profile one.
I tried the bottle jack and it didn't look safe to me - the emergency scissor jack worked but was hard work and virtually at its top before the wheels left the ground. only just gave me clearance to swap the wheels...
Cheers Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #411536 31st Oct 2016 9:35am
Mine arrived - seems OK, but the release valve is separate from the handle, so you can't just twist to drop - but I can't complain for �58.
I like the carry handle though as I have a gravel drive Thumbs Up
Another couple of weeks until the winter wheels go on and I try it properly
Post #412176 4th Nov 2016 9:29pm
