Home > General > IID tool help in bristol?
Dolphinboy
Would any very nice forum Member who has an IID tool or similar in bristol be so kind as to let me come round and have a quick fix asap this week?
Just about to go for my MOT and got an ABS light just come up.
Many thanks.
DB
Post #411485 30th Oct 2016 10:19pm
Jambo
United Kingdom 2012 Range Rover Westminster TDV8 Santorini Black
Not an expert by any means, but I think the tool is locked to a specific vehicle VIN number.
Sure others will be along to soon with more info....
Post #411487 30th Oct 2016 10:43pm
Stacker
United Kingdom 2003 Range Rover HSE Td6 Adriatic Blue
As far as i believed the VIN lock was only for CCF editing?!
ICarSoft i930 will give you a readout and reset the light if the problem is fixed!
Post #411493 30th Oct 2016 11:15pm
Jambo
Ah yes, could be, sorry - my mistake Embarassed
You can probably clear faults, but not re-programme.
Post #411498 30th Oct 2016 11:30pm
Dolphinboy
Happy to use any other type of OBD machine (ICarSoft i930 or other) just to find out where the airbag fault is. Mr. Green
Any Brizzle boys out there able to help please? Big Cry
PS would effect would removing the relevant fuse have? Would I need to remove battery earth/Neg wire in order to remove fuse? Would it get through the MOT without a fuse in place?
Thanks
DB
Post #411710 1st Nov 2016 5:45pm
Airbag light is a hard fault mate, doesn't matter what you do it will stay, your original post said ABS light though so I'm confused....
Thumbs Up Pete
Post #411728 1st Nov 2016 6:47pm
Dolphinboy
Oops apologies Pete. Bloody autocorrect! Have edited to airbag now.
Post #411850 2nd Nov 2016 11:33am
Clivefog
If you don't get any help over the weekend you can try mine Monday after 4.
Post #411907 2nd Nov 2016 5:20pm
Dolphinboy
Thx Clive very kind (again).
you were my next port of call but I wasn't sure if your one would fix a hard fault like an airbag. We can but give it a go!
Ps are u around Friday by any chance? Mr. Green
Post #411921 2nd Nov 2016 7:56pm
Clivefog
No I'm in Hartlepool. Had I known I could have left the reader with my son - mind you getting him out of bed...........
Post #411931 2nd Nov 2016 9:17pm
Dolphinboy
Rolling with laughter Rolling with laughter
Know what you mean. If only I could get my little one to be like him! Bow down Thud Thud
Post #411943 2nd Nov 2016 11:32pm
