![]() | Home > Technical (L322) > Range rover and x5 engine differances and essential mod. |
Lukie Member Since: 27 Sep 2016 Location: Liverpool Posts: 433 ![]() ![]() |
are the cam / cranks the same ? a mate of mine once changed an engine in a voyager same engine numbers but the electric's were diffrent in the years, he had to then strip cam shaft and crank shaft replace them with the other's |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8546 ![]() ![]() ![]() |
Excellent info, thanks for posting, always wondered if the S62B50 M5 engine which is based on the M62 would fit... also the later M62B48 4.9ltr...
Phils Member Since: 01 Aug 2016 Location: North west Posts: 71 ![]() ![]() ![]() |
The s62 is a much more powerfull engine and is based on the m62, but it is not electrically compatible with range rovers or x5`s. It has two vanos per bank, intake and exhaust. Rr has one on the intake. And there are other differences.
Oh, I know they would be extra work, just be something different... probably easier to drop in an american small block crate motor and run it on Megasquirt or similar...
Yes i looked it up. I was unsure alpinas 4.8 was an m62 engine. Wikepeadia confirmed it was.
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1001 ![]() ![]() |
There was an ‘035’ version of the ZF 5HP24 transmission which was used in the Alpina B10 (E39) and the Z8 Roadster (E52) but I think these may have had the 4.6 engine still, and not the 4.8?
Hi phil
From what I can tell, the 034 and 035 transmission hardware is identical, beyond the obvious 4WD vs RWD differences.
Interesting.
Yes, I notice that a lot of people on the American BMW E53 forums bang on about 'Dinan' transmission software upgrades on their 5HP24s : http://www.dinancars.com/products/?series=...ine-tuning
