Home > Maintenance & Mods (L322) > Finally pulled my finger out and cleaned the fog lights
3528cc
United Kingdom 2008 Range Rover Autobiography 4.2 SC V8 Buckingham Blue
After looking at the milky fog on the inside of the fog lights I finally dismantled them and cleaned them
Surprisingly easy, kicking myself for not doing it sooner, only had the car two years Rolling Eyes
I'm sure it's probably been covered before........
1) pulled bezel off (watch for the clips coming off, mine had a few missing already, will order a pack of new ones , 5 per bezel)
2) Remove lamp, three Philips screws, later cars maybe torxs
3) remove bulb, twist off
4) Remove adjusting screw brackes (torx screw)
5) Carefully remove the reflector, two plastic clips to spring
6) Clean glass lens and the reflector. (I used a micro fibre cloth dry)
7) re assemble, reverse order of the above instructions
Before
After
 Regards
Royston
2008 4.2 Supercharged Autobiography
1994 Classic Vogue SE
1999 Rover BRM
1987 Rover Vitesse Twin Plenum
Post #411279 29th Oct 2016 4:35pm
georgedb
South Africa 2006 Range Rover Supercharged 4.2 SC V8 Java Black
awesome 3528cc.
Looks neat.
Thanks for sharing
Post #411280 29th Oct 2016 4:39pm
kbald
Nice mine are all milky but didn't know you could clean them! That's a job for tomorrow then!
Post #411286 29th Oct 2016 5:29pm
Lukie
2002 Range Rover Vogue 4.4 V8 Zambezi Silver
I'm thinking of changing my fog lights. seen some fog lights with halo side lights on them to
Post #411354 29th Oct 2016 11:05pm
3528cc
Onto the main stealer today, apparently the clips are not available separately from the bezel Censored , does anyone have any suggestions where I could possibly get an alternative clip Confused Regards
Royston
1999 Rover BRM
Post #411624 31st Oct 2016 8:40pm
marsie
England 2014 Range Rover Vogue SE SDV8 Loire Blue
Thanks, thats another job on the list for mine now Thumbs Up Looks loads better Paul
2014 Range Rover vogue se 4.4sdv8 Loire Blue
1992 Range Rover Vogue LSE 4.2 Ardennes green
Post #411628 31st Oct 2016 8:55pm
