![]() | Home > Technical (L322) > Help: ZF 5HP24 Transmission vibration l322 V8 2002 |
ohuntsman Member Since: 21 Mar 2016 Location: Surrey Posts: 337 ![]() ![]() ![]() |
When cruising on the motorway an intermittent noise in the cab comes from under the gear shifter that sounds like driving on the white rumple line on the motorway.
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 830 ![]() ![]() ![]() |
Like driving over a cattle grid maybe? ______________________________
Not that intense, you know that white line at the edge of the central reservation on the motorway or dual carriageway when you dose off slightly and it wakes you up when you drift over it- a softer version of that |
Yes to the slight incline, not sure on the other bits but it will happen at slower speeds- I would tak it for a test drive but it failed it's mot yesterday so totting up jobs for the weekend.
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
typical torque converter failure is vibration up until around 55 to 60 mph when holding a steady light accelerating throttle up a slight incline.
Thank you buddy, I've pm'd RRPHIL |
Normally if it is just the noise and nothing else then phil keeps the refurbished items on the shelf and it's a case of transmission off, swap over TC, transmission on which sounds simple and it is if the transmission didn't weigh so much.
How long did it take? Do you need the jig tool? |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8396 ![]() ![]() ![]() |
You don't need any special tools, tranny out and in is a good days job with a ramp, on the floor I'd allow a weekend for it... Book time is 5 hours...
And get a transmission jack, and we made full length ramps but as a decent garage can do it in a few hours then i would ask an indy but get your TC from Phil so you know it has been properly refurbished as it is a specialist job.
Ahh awesome thank you buddy- how much did the repair cost you? |
Much easier if you take the transfer box off the back first, doesn't spill any oil or need any gaskets, does make it that bit easier though.... |
I have since removed and refitted the transfer box separately and that does weigh a lot on it's own and again took me a day to try and get it back in on my own without a lift just a trolley jack and ended up getting a neighbour to help, damn that gravity...
Coolio thank you- love the ramps- I've been eyeing up two post lifts on gumtree- some 3 tonne ones start at around £400.... but the directors may have something to say about that going up outside the flat |
