![]() | Home > Technical (L322) > Windscreen wipers stopped |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2272 ![]() ![]() ![]() |
Hi all my windscreen wipers stopped the other day all of a sudden nothing moved the stalk up down - nothing switched off took key out restarted all ok anyone had this before? |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3659 ![]() ![]() |
YES |
Just had a look.... there is some good news and some not so good news...... Good news is the wiper relay is for 2002-2009 and is cheap as chips ..... first example I found.... https://www.britishparts.co.uk/products/8964-relay-YWB000060G
Its still working at the moment but off on another 2000 miler soon so will buy a relay and swap just in case have had battery in and out a couple of times as put a new one in every two years regardless ta for info |
SveinHa Member Since: 22 May 2016 Location: Karmøy Posts: 36 ![]() ![]() ![]() |
My wipers fail when they run more or less constantliy for half an hour or so. Shut down and restart the car don't help but after 2-3 minutes they start if I stop and start the wipers with the switch on the steering column (or restart the car but I HAVE to wait a few minutes).
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1393 ![]() ![]() ![]() |
This happened with my 2004 car, intermittent fault, I assumed it would be the relay as it usually is, but it turned out to be something else, found by diagnostic machine, I'm afraid I can't now remember what it was though, so worth running a diagnostic check before doing the relay. Only Range Rovers since 1988 |
I would say that if your car has 110K + then you should be thinking about changing the relay, just in case... lets face it, it's a £15 item and you don't have to be a rocket scientist to change it, although being built like a brick s*** house will be an advantage |
