Home > Technical (L322) > No central locking after mirror repair |
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 |
I did the very same...try pulling fuse,checking it then replacing it..doing so got mine working...even if its not blown the fuse pull helps sometimes |
23rd Oct 2016 6:15pm |
RRV78 Member Since: 15 Sep 2016 Location: Truro Posts: 203 |
I have done a battery reset on it and still the same, I have pulled about four fuses in the glove box to check them and they all seem ok. |
23rd Oct 2016 6:18pm |
F11 and f24 if I remember correctly solved mine.. |
23rd Oct 2016 6:26pm |
Is that the glove box fuse board or another one in the car? |
23rd Oct 2016 6:35pm |
Glove box mate..fuses for drivers and passenger door modules..i found them by downloading range rover electronic library... |
23rd Oct 2016 6:43pm |
23rd Oct 2016 6:45pm |
Thanks for that I will have a play tomorrow now! |
23rd Oct 2016 6:49pm |
Good luck! |
23rd Oct 2016 6:51pm |
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 |
When I replaced the drivers side door handle cable on mine driver door central locking wouldnt work after I'd put it all back together. After much checking of fuses, battery resetting, swearing etc it was simply that I'd not fully pushed home one of the connectors in the door card. Not sure how much you had to dismantle, but if all else fails its got to be worth checking.... 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car! |
23rd Oct 2016 8:53pm |
I have had the door card off three times now but will be out there tomorrow trying fuses and giving all the connections an extra tweak I'm getting close to turning the air blue. |
23rd Oct 2016 9:01pm |
Well after a lot of swearing and testing of various wires and components mine also turned out to be a bad contact on the white plug going into the door card.
25th Oct 2016 11:36am |
