Home > Other Site Sponsors > J-B Weld at Opie Oils for as little as £4.88
oilman
J-B Weld has been the market leader in epoxy resins, adhesives, thread lockers and specialist products for over 40 years. J-B Weld has built up a loyal following of customers who have all shared the same experience after using any J-B Weld product .
J-B Weld is a staple of every repair professional and DIY enthusiast’s toolbox and has been given the title of ‘Worlds Strongest Bond’ for a reason. No matter the problem there is a J-B Weld solution.
J-B Weld is perfect for [url=http://www.opieoils.co.uk/c-3272-j-b-weld.aspx#Filter=[EntityIDs=@(1028)@*ava=0] High Heat Repair [/url], [url=http://www.opieoils.co.uk/c-3272-j-b-weld.aspx#Filter=[EntityIDs=@(1023)@*ava=0] Wood Repair [/url], [url=http://www.opieoils.co.uk/c-3272-j-b-weld.aspx#Filter=[EntityIDs=@(1025)@*ava=0] Plastic Repair [/url], [url=http://www.opieoils.co.uk/c-3272-j-b-weld.aspx#Filter=[EntityIDs=@(1022)@*ava=0] Marine Repair [/url] & [url=http://www.opieoils.co.uk/c-3272-j-b-weld.aspx#Filter=[EntityIDs=@(1024)@*ava=0] Metal Repair [/url].
Need help finding the correct J-B Weld ? Please click HERE to see the Automotive Application Guide.
Confused by the different types of Application? Don't worry Opie Oils are here to help.
PUTTY
Overall low tensile strength but can be moulded to the needs of the repair and can be layered to fix larger areas so putty is very good at the
repair of holes etc.
ADHESIVE
Comes with two tubes, epoxy and hardener to be used to create own mix for different needs. Experience of
J-B Weld products and epoxy adhesives is needed to get the best results.
SYRINGE
Creates a perfect 1:1 mix of epoxy and hardener, for ease of use and novices.
Having problem with Fibre Glass? Try J-B Weld PlasticWeld Epoxy Putty
J-B Weld is one of 93 Top Quality brands Opie Oils stock. To see all 93 brands please click HERE
That’s all from us today, if you need any help on our J-B Weld range please get hold of us on 01209 202944 or email us at [email] sales@opieoils.co.uk [/email]
Cheers
Oilman Use the code FULLCHAT and get 10% Club Discount
oilman's website: www.opieoils.co.uk - register for news and offers www.opieoils.co.uk
email: sales@opieoils.co.uk
phone: 01209 202944
Post #410636 25th Oct 2016 10:21am
