Home > Maintenance & Mods (L322) > Fault Code P040D update |
Giantlandyman Member Since: 25 Nov 2015 Location: Essex Posts: 800 |
Following on form this thread http://www.fullfatrr.com/forum/topic38652.html (which has other links within it) I have had confirmation from LR CRC that this is a "false flagging DTC or Ghost Code" which is not of any concern. It will have no effect on functionality and and "if the concern was to affect emissions it would place an EML light on the instrument cluster."
27th Jul 2016 9:50am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35274 |
a quick google of that code comes up with,
27th Jul 2016 9:55am |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3233 |
As I remember it, the full code is P0040D (XX) where "XX" seems to define the exact location, which would indicate refinements in meaning. I know that in Buz1500's case the code was (2F), which may be the same as you have. Other results have been reported. As you will have seen from his thread, his independent advised that there was no immediate problem but replacing the sensor when he returned home would be a sensible approach. Seems to bear out your own conclusions. HTH John 2008 Stornoway Grey 3.6 Tdv8 Vogue 2005 TD6 Java Black Vogue - Written off!! GAP iiD BT 2003 Discovery TD5 Auto, Nanocom Evolution - gone to a new home! MasseyFerguson 152 - No electronics!! - Sold |
27th Jul 2016 10:14am |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2475 |
I replaced mine's EGR temp sensor because of the fault code. On dismantling the front section of the EGR pipe that fits inside the inlet manifold to check on soot build-up I noted the copious amounts of soot lining the EGR pipe and the inlet manifold. I don't know if the reportedly failed temp sensor had anything to do with the huge volume of carbon but with less than 40K kms on the vehicle and 22K of those in the preceding 10 months and mostly open-road cruising, I'm rather dumb-founded at the extent of the build-up. |
27th Jul 2016 11:59am |
^ That doesn't good at all.
27th Jul 2016 6:03pm |
The original owner only did 18K kms in 3 years so barely used. However most of my driving is in top gear at around 1200/1400 rpm so also a likely cause but I wondered if the reportedly faulty EGR temp sensor triggered the EGR cooler to over-cool he exhaust gases causing he excessive deposits. I'm now waiting for the final touches to an EGR emulator to be done that will stop all EGR. |
27th Jul 2016 8:45pm |
Landphil Member Since: 03 Oct 2016 Location: U.K. Posts: 119 |
I have had my Westminster for two weeks and when I put my IID on it flagged up the code P004D-(2F). So booked it in and a new sensor fitted under LRA warranty. Just got home and guess what, it's back.
20th Oct 2016 1:38pm |
I was given some more information about this fault only the other day.
20th Oct 2016 4:42pm |
I don't know the ins-and-outs of why they decided to change it under warranty but may find out next week. All I know is that it was present when I checked the fault codes after buying it so maybe they are just being "nice" to me - won't last long I bet.
20th Oct 2016 4:53pm |
"But the car is running very well."
24th Oct 2016 8:40pm |
sorry to hear that phil, hope it gets sorted ... ... - .- -.
24th Oct 2016 8:48pm |
Full Fat loaded onto a low loader and gone back to MD. Now driving a Disco Sport HSE with the new engine. It doesn't really feel like a LR but goes well, jury is out but I don't think I would buy one and it definitely isn't as good as my Freelander 2. |
25th Oct 2016 4:21pm |
Car returned this PM with new EGR bypass valve fitted. So far so good, running like clockwork, fingers crossed. |
1st Nov 2016 5:40pm |
