Home > Maintenance & Mods (L322) > TD6 alternator rebuild questions
joeypineapplez
Ireland 2002 Range Rover HSE Td6 Epsom Green
My alternator has packed up after 137,000 miles. I believe it to be the original but cannot confirm. Its a Valeo YLE 500051.
A new genuine item is out of the question so I have 2 choices. Cheap after market item or rebuild my own. Obviously I prefer to rebuild my own. Im handy with spanners so thats not a problem. Finding good quality replacement parts is the tricky bit.
Any advice from someone whos done it.? Where to source parts.? Any known failure component in these.? Etc
Thanks. 2002 TD6 Epsom Green
Post #410415 23rd Oct 2016 6:08pm
Ask these guys, they can usually help...
http://www.jcrsupplies.co.uk/products/ALTERNATOR_REBUILD_PARTS
If light came on it's usually brushes, if it didn't then it's usually the diodes, I'd change the lot and the bearings....
Thumbs Up Pete
Post #410438 23rd Oct 2016 8:14pm
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
Have you seen this video on youtube? brushes and regs are plentiful on ebay...
https://www.youtube.com/watch?v=aVvPzwtxdrM 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #410461 24th Oct 2016 4:35am
joeypineapplez
Cheers for the links chaps. Thats the way Im gonna go. I may try and photograph my experience if all goes well. 2002 TD6 Epsom Green
Post #410534 24th Oct 2016 3:49pm
It's very easy to do, done loads... sometimes the bearings can be a pain but to be fare they are much better than they used to be so left a lot of them alone...
We rebuilt one at a play day a few weeks back, one of the brushes had snapped clean off, managed to rob another one out of an old electric motor, cut it with side cutters until it fitted and pushed it in on top of the broken original... Censored thing only worked perfectly... and was still going two weeks later when swapped....
It's amasing what you can bodge up when you need to... Pete
Post #410547 24th Oct 2016 4:39pm
