![]() | Home > Technical (L322) > Has anyone managed to do an EGR delete on a TDV8? |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
Just thought that I'd ask the question as I stumbled on something that may be of interest on a another site...
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
I had mine mapped out a few weeks ago No error or faults codes showing 2015 4.4 AB
Gunning Member Since: 28 Sep 2016 Location: Cornwall Posts: 237 ![]() ![]() ![]() |
The issue is with that is I have no idea if it'd relate to a tdv8 and I'm certainly no mechanic to start trying that! 19 L405 4.4 AB + Disco3 pick up + 800BHP Rothmans 911
Bluegreygreen Rangie Member Since: 10 Aug 2012 Location: Australia Posts: 53 ![]() ![]() |
For the 3.6TDV8 you can get egr emulators, and a few mapping places are deleting" the egr part of the map so they say, either way ill be working out what is the best way to go cost wise more than anything and be doing mine asap... ill report back when done
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
I've done about 8000km with emulators now. No problems. I'll just leave them in there closed off. I might look at seeing if the cooling system can bypass the EGRs. ______________________________
As far as I'm aware, you can't actually totally map out the EGR's they can just dia them back to the point that they have little or no impact on the engine.... but that doesn't mean that they can't fail... which would then throw up a fault and cause limp mode |
Did you notice much in the way of imediatly noticable improvements, sound and economy etc 2010 TDV8 Autobiography Past - 02 & 03 TD6 And an 1984 Classic GAP Diagnostics |
The tdv8 seems a very well balanced smooth motor. But it was noticibly smoother and quieter after the emulators were fitted. There might be a small improvement on economy but too little to be really noticible.
Sounds good |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1462 ![]() ![]() |
I read on another forum that removing, blanking off or disabling EGR valves might result in an MOT failure as it is modifying the emissions system which the vehicle was previously approved with.
AFAIK the Nox isn't tested for the MOT as of yet so deleting the EGR function will not effect the MOT, however removing all traces of the EGR will cause you MOT problems, but as far as I know they aren't easy to see with the engine cover on |
berkshirelad Member Since: 06 Apr 2016 Location: Newbury Posts: 265 ![]() ![]() ![]() |
Removing the EGRs or fitting emulators will not affect the current MoT in any way.
ije44 Member Since: 01 Sep 2015 Location: Leicester Posts: 133 ![]() ![]() ![]() |
Hello all,
