Home > Technical (L405) > Can you retrofit front fog lights ?
Without a headache ?
Very Happy All my spelling errorz are belong to me!
2024 RR Velar
2021 AM new Vantage
Post #409801 19th Oct 2016 7:36am
Doodle
Gutten morgen,
If the wiring loom is universal across all 405 models then it's possible.
Depends where the connection is located. Also, does the stalk have the connection for on/off as for rear fogs (as same stalk)?
Spec from new I think it was about £100 on mine, so good value.
That's probably around 10 toy money Euros this week!! Rolling Eyes
Post #409827 19th Oct 2016 11:50am
i found a new pair for 200 Euros in the UK.. All my spelling errorz are belong to me!
2024 RR Velar
2021 AM new Vantage
Post #409828 19th Oct 2016 12:09pm
Doodle
That's good value.
Be interesting to know how you install them.
Hope the connectors are somewhere behind the bottom valance. Good luck.
Post #409831 19th Oct 2016 12:16pm
362bkr
I nearly bought one without fogs and the dealer quoted £ 1200 to retrofit them . I didn't buy that car ...............
Post #409833 19th Oct 2016 1:05pm
I think the retrofit is expensive and not the parts... Crying or Very sad All my spelling errorz are belong to me!
2024 RR Velar
2021 AM new Vantage
Post #409837 19th Oct 2016 2:22pm
Including the parts to switch them on ?
Or does your car already have the switch ?
Post #409838 19th Oct 2016 2:24pm
http://www.ebay.de/itm/Range-Rover-405-Ran...Sw0fhXkLw-
i think it is the light only Sad All my spelling errorz are belong to me!
2024 RR Velar
2021 AM new Vantage
Post #409840 19th Oct 2016 3:16pm
Nick Ground
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Indus Silver
Replacing a complete column switch will no doubt be very expensive! The dash graphic is free and the wiring loom is probably already there. Programming the CCF file?
Nick 2019 D5 HSE Lux SDV6 Indus
55 D3 SE
98 MX5 1.8 RS
gone 17 older variants of FFRR
Post #409875 19th Oct 2016 6:41pm
I see - a costy headache... Big Cry All my spelling errorz are belong to me!
2024 RR Velar
2021 AM new Vantage
Post #409895 19th Oct 2016 8:25pm
paulmoran2
England 2013 Range Rover Vogue SDV8 Mariana Black
Wouldn't you also need the front black plastic section that runs the full width to mount the fogs into also?
The non fog trim doesn't look like it'll accept the fogs? GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
HAVE 1999 Discovery 2 GS 4.0 V8 - Silver - Off Road Toy
GONE 2013 L405 4.4 SDV8 Vogue. Black with Silver roofline and 22" s
HAVE 2015 Jaguar XF.
Post #409897 19th Oct 2016 8:47pm
Rob99
Can't believe a VSE doesn't have them as standard Confused 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #409899 19th Oct 2016 9:23pm
The German VSE seems to be a bit different - Frank has also changed his door handles nd front side vents to the same as the UK VSE spec
Front fog lights are useless anyway Whistle
Post #409902 19th Oct 2016 10:02pm
Useless perhaps, but i want the look of it - btw my car is fully loaded like an AB - weird the previous owner did not ordered the fog lights when new - FFS ! Mad All my spelling errorz are belong to me!
2024 RR Velar
2021 AM new Vantage
Post #409922 20th Oct 2016 8:05am
andy2577
United Kingdom 2014 Range Rover Autobiography TDV6 Santorini Black
You will need a new front bumper , front bumper wiring harness and a new switch
The black part of your bumper is not sold separately and can't be removed as it is plastic welded in .
Wiring loom should be a plug and play unit , worse case you need a new engine harness which is VERY expensive as the fog light wiring runs through the engine harness and into the fuse box under the front passenger footwell 2002 - Blue L322 3.0 TD Vogue (Previous)
2006 - Black L322 4.4 V8 Vogue Autobiography (Previous)
2014 - Black L405 3.0 TDV6 Vogue Autobiography (Present)
Post #420758 2nd Jan 2017 3:37pm
