Home > Technical (L322) > Air Suspension
SHasson1690
United Kingdom 2002 Range Rover Vogue 4.4 V8 Giverny Green
Air Suspension
Today my air suspension inactive fault appeared.
Now have no lights on control switch inside car, is this normal. prior to this a sort of rumbling was heard then fault appeared. Im assuming compressor is gubbed, new replacement on order.
Does the error code have to be rest after installation of replacement part ?
Car is 4.4 V8 petrol ( 02 )
thanks in advance
Stephen
Post #409551 16th Oct 2016 6:01pm
alistairh
I've just fixed mine..car was giving the air suspension inactive message and control was unlit...it could be a lot of things tbh..i bought an icarsoft which told me reservoir pressure was static and with the help of some forum members I was able to start pinpointing the fault...
certainly I good investment to get a decent diagnostic instead of throwing parts at thw car..in the end it was.my compressor that was worn to the point it could only pump out 0.09 bar...
Post #409553 16th Oct 2016 6:17pm
alistairh
Have you tried turning the steering wheel full lock left to right to clear message on cluster?
Post #409554 16th Oct 2016 6:18pm
Turning wheel won't help unless you have disconnected the battery....
As has been said, no good guessing what's wrong, could be loads of things that give the same fault, get a reader or get the codes read... Thumbs Up Pete
Post #409556 16th Oct 2016 6:32pm
SHasson1690
Re: Air Suspension
thanks in advance
Stephen
Replacement compressor fitted, car back to 100%
Thanks for the information. Cheers
Post #410575 24th Oct 2016 8:16pm
alistairh
Great! Thumbs Up
Post #410576 24th Oct 2016 8:23pm
