Home > In Car Electronics (L322) > Nokia Hf kit
rattly
Nokia Hf kit
Does anyone know which fuse/or how is dis-connect the Nokia Hands Free kit that is still in my RR, hoping its the cause of my battery drain, headlamp wipers work and sat nav is shutting off! Crying or Very sad
Post #409552 16th Oct 2016 7:04pm
I would imagine it depended on who fitted what Nokia kit... If you can't find it to remove it then it's probably best to go to an auto electrician... Thumbs Up Pete
Post #409557 16th Oct 2016 7:34pm
See here if like the one I had/have....
http://www.fullfatrr.com/forum/topic35589.html
Mine was tucked away under the glovebox/dash console .
Post #409569 16th Oct 2016 10:10pm
rattly
Hi Joe90...That`s the one, I`m not too worried about removal, just dis-connection for now, keep getting flat batteries if RR not used for 4/5 days! The blog mentioned fuse 22, do you think could I just remove this for now?
New battery fitted and all charge rates are ok... Fuse 49 for amp etc removed today and will leave it for a few days.
I`m hoping to cure this as part of a much bigger problem, please see my "select neutral" post for full story!!
Thx in advance...
Post #409575 16th Oct 2016 10:37pm
Just find the box of tricks under the dash and disconnect everything .
Post #409581 17th Oct 2016 12:18am
