Home > Technical (L322) > key synchronization issue
alistairh
Hi...when i first got the fatty its key wasn't synchronised..did the procedure with the unlock and lock buttons and it then worked...anyway I locked it and unlocked it 4 times on the run the key went out of synchronization and now it refuses to re sync! Is it possible to have blocked something doing so and would a battery reset help? Thanks
Post #409059 12th Oct 2016 7:48pm
rar110
If using the IIDTOOL make sure it has a software update and your phone app is synced with the device after the update (assuming you use the IIDTOOL with a phone app). ______________________________
Post #409080 12th Oct 2016 9:56pm
alistairh
I've not got my iid tool yet only a basic icarsoft..the iid tools here shortly! Ive synchronized it via the keyfob procedure..it doesn't work anymore though...going to defo try a battery disconnect first...already tried replacing keyfob batterie..failing that will order a rf receiver from ebay and try that!...defo something to do with me rapidly locking/unlocking car 3/4 times at once..
Post #409082 12th Oct 2016 10:10pm
alistairh
Tried a battery reset! Just as I thought nothing! Banging Head Found lots of rf receivers on ebay for sweeties..thinking of replacing it in the hope its that that's decided to stop working..failing that is there a newer version available? Process of elimination again Laughing
Post #409184 13th Oct 2016 7:23pm
