Home > Maintenance & Mods (L322) > 1l engine oil refill every 1.000 km ?
gillech
Switzerland 2003 Range Rover HSE 4.4 V8 Adriatic Blue
RR 2002 gasoline V8 (4.4 BMW engine ) - 50.000km
hi everyone
i have been checking the engine oil level for some time now and it appears that i have to add regularly 1liter of engine oil every 1.000 km.
is this normal, my engine being low mileage (50.000 km) ,
i can't see any blue smoke from exhaust, ( except sometimes right at engine start, but not more than that.)
checking under the car I discovered an area stained with oil, which i showed to a dealer.
they said there is a little oil escape coming out at the rear end of the automatic gearbox and it is coming from gearbox, not from the engine .
i am confused now about the case , not knowing where is the problem...
so if you would be kind to help me understand :
is it normal for the engine to consume 1 oil liter every 1.000km ? ( car shows no blue smoke at exhaust )
is it possible that the leak , apparent at the rear end of auto gear box, would be leaking from the engine itself?
in this case, where are the most probable places that should be checked to find out the engine oil leakage?
thank you for helping me
Post #408107 7th Oct 2016 11:37am
Dolphinboy
Definitely not normal usage! I barely put any in mine between services. I would say you have a leak, poss a cam gasket or poss out of the drive shaft junction underneath where it goes into the gearbox or the engine.
Post #408108 7th Oct 2016 11:41am
153,000 miles (246,000km) and it doesn't use a drop, ever....
So as "Flipper" says, something is wrong..... Pete
Post #408111 7th Oct 2016 11:53am
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Check out the small rubber hose coming from the oil separator at the rear of the engine, it's on the left side as you look at it from the front.
Mine had deteriorated that much it resembled chewing gum (no exaggeration) and had snapped in the middle.
This lead to an oil leak that blew back underneath the car giving the impression that it was coming from the rear of the gearbox, it can and does lead to excessive oil loss and 1 litre every 1000km sounds about right.
Regards ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #408114 7th Oct 2016 12:02pm
Dolphinboy
"flipper"!! Rolling with laughter Rolling with laughter Bow down Thumbs Up
Post #408128 7th Oct 2016 1:19pm
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
Never added a drop in between services
+1
Post #408263 8th Oct 2016 9:40am
