Home > Technical (L322) > Xmas light
Patrickthier
United Arab Emirates 2002 Range Rover SE 4.4 V8 Alaska White
Xmas light
Hi,
I have numerous electric issues;
1/ Each time I start the engine hazard switch on automatically. I push the hazard button and it stops, no worries but next time I'll start same story again.
2/ When I stop the engine, the steering wheel goes to the top but the steering tilt motor continues to work until I touch the switch control;
3/ Airbag light is always on.
4/ Intermittently most of the dashboard light come on. I just have to re start and it's fine until it comes comes again.
5/ Regularly I have different alert message, "Suspension inactive" "Trans fail safe mode" It comes and goes
6/ When I stop the car and close it, I have the red light close to the descent switch that goes on until I unlock the door next day;
7/ Sometimes when I lock the car the screen of the radio (sat nav) switch on with Land Rover logo and doesn't switch of. I need to reopen & to restart & close the car again to make sure the radio is off with black screen.
Any idea what goes wrong there?
I also discover today on passenger side it seems I have a water leek, should be AC. I did not investigate yet. But no smell and no taste;
That's all for today.
Otherwise what a great car. I love it so much but those electrical issues scared my wife now I have to fix it.
I really need your help;
Post #407195 30th Sep 2016 9:16pm
paulmoran2
England 2013 Range Rover Vogue SDV8 Mariana Black
Hi Patrickthier.
If you have a multimeter , start the car and check the voltage going into the battery from the alternator and post back the result.
Also, how old is the battery? GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
HAVE 1999 Discovery 2 GS 4.0 V8 - Silver - Off Road Toy
GONE 2013 L405 4.4 SDV8 Vogue. Black with Silver roofline and 22" s
HAVE 2015 Jaguar XF.
Post #407218 1st Oct 2016 7:30am
Patrickthier
Hi,
Battery is almost new, less than 2 months.
I dropped the car to the shop this morning, I did not check the voltage but I'll do as soon as I get it back.
Another issue came during the week end, engine seems to have only few cylinders working from time to time with tachometer moving from 1 to 1.2 and accelerator absolutely ineffective. I have to turn off and turn on and everything goes well!!! Until next start.
I know what British engineering means now! Luckily that's BMW engine.
Post #407480 3rd Oct 2016 5:28am
rar110
The symptoms sound like a low voltage issue. First, check the battery connections are tight. Next after car has gone to sleep check the battery voltage. It should be 12.6v plus, being a new battery. The next check would be the alternator. ______________________________
Post #407515 3rd Oct 2016 10:38am
Imbigt
A bad earth maybe
Post #407578 3rd Oct 2016 6:44pm
Patrickthier
For the time being, it seems to be AC related.
Passenger carpet is / was full of water.
We use AC 10 months a year here. I don't know for how long passenger carpet has been wet. It damages a couple of electric connector / wiring.
Some new pics.
Let it dry and see how it goes
Post #407637 4th Oct 2016 4:51am
