Home > Technical (L322) > DRL Bulbs
Saunders
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
DRL Bulbs
Hoping some of you may be able to point me in direction of finding low voltage DRL "eagle" style bulbs?
I have just tried changing a few that sit in the overfinch surrond in the lower partbumper. However, it appears the power feeding these is only 4.6v whereas the lights I have bought and all the ones online seem to be 12v.
Unfortunately can't find any markings on the existing light.
Any help would be appreciated.
Post #407308 1st Oct 2016 6:27pm
Saunders
Really struggling to find anything similar. After looking online, it looks like I need the attached light, but not the large surround. Anybody recognise this and advise where I need to look? Starting to think the previous owner may have had these made specifically?
Post #407638 4th Oct 2016 5:06am
Saunders
Here's a photo of what's already fitted. Does anybody recognise these and can advise what I need to be looking for?
Thanks
Post #408438 9th Oct 2016 11:01am
if its an overfinch bulb then it will be a specialist type.....try the 12 volt ones ,they might accommodate the lower voltage.. ... - .- -.
Post #408440 9th Oct 2016 11:04am
Saunders
I'm not entirely sure if it is Overfinch, it's mounted in the Overfinch vents in the lower part of the bumper. But I've now seen others with this and no lights so I'm starting to think it could be bespoke from a previous owner.
I'll see if Overfinch can help, if not I think I'll have to change all the bulbs and feed off 12v. Just frustrating as the correct fittings must be somewhere!
Thanks for your help.
Post #408445 9th Oct 2016 11:33am
