Home > Maintenance & Mods (L322) > Genuine land rover iPod kit
kil2508
Wales 2005 Range Rover Vogue Td6 Java Black
Hi guys
Just a quick one, do land rover do an iPod kit that is retro fitted?
My rangie is a 2005 facelift model
If so and anyone knows the part no and cost I would appreciate it if you could let me know
Cheers
Gav
Post #40730 3rd Dec 2010 5:21pm
gav, do a search theres loads on this.... ... - .- -.
Post #40795 4th Dec 2010 12:12pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
I have a 55 SC and got one from eBay.
Fitting required taking top off dash and glovebox out. Bit more diddly with the older car as the audio ECU is behind the touchscreen (vs above the glovebox post 56 reg)
Works perfectly.
Got some great help from the seller.
Some quick points:
To take the top off the dash. Remove all visible screws and also take the side vents and speaker cover off as there are other screws there. I took the dash speaker out as the cable is short. Pull the dash pad towards you and then lift up.
The left dash vent cup holder is held in with a 10mm bolt.
The glovebox is held in with torx screws (think it was a T15 driver IIRC)
Glovebox can be fiddly to re-fit but be patient and it will drop in.
I found the panels all go back beautifully.
Pick one up and have a go. Thumbs Up
Post #40800 4th Dec 2010 12:22pm
