Generally speaking the camber doesn't need adjusting. On the top mount the strut locates with a pin through the mount. To adjust the camber this needs removing and then a special tool is used to pull the strut top to the correct position. As Pete says, it's worth getting it checked again.
Just Before you get it put on the rig I would raise it up then put it into normal mode then drive it onto the ramp to make sure that the suspension is settled it should be done in tight tolerance mode but that will require a diagnostic, which the garage is unlikely to have, but If the wheel sensors aren't pushed home they can give bad results too. There is nothing that can't be fixed with a hammer😜😜
