![]() | Home > Maintenance & Mods (L322) > Which Optima battery can I install? |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
I think you'll be lucky to get an optima battery to fit full stop... the range rover batteries are derived from BMW and as such they tend to be long and shallow... where as the optima batteries are regular shape and rather tall for a ffrr.
Have a look at this |
bruzer Member Since: 16 Nov 2015 Location: Seattle, WA Posts: 44 ![]() ![]() |
Hmmm... what about another make and model battery that fits and does well starting up with extra electronics installed? |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1560 ![]() ![]() |
a small 54Ah Optima will fit there as a second battery. That's too small for me, I want 100Ah for camping. Ron B. VK2OTC 2003 L322 V8 Auto 2007 Yamaha XJR1300 Previous: 1983, 1986 RRC; 1995, 1996 P38A; 1995 Disco1; 1984 V8 County 110; Series IIA |
I currently have a Interstate Batteries MTP-49/H8 100AH which is listed as 900 cranking amps and 730 cold cranking amps, so anything more powerful than that or that will stand up to a car with a lot of electronics. |
Right there are a few things that you should know, Firstly your battery is a lead acid battery... ffrr's should have a calcium battery |
So what's the number I need to pay attention to if I want the vehicle to start up reliably with extra electronics installed: capacity, cranking amps or cold cranking amps? |
The higher the Ah the larger the capacity, and it will therefore last longer.... The important thing is to try and get a AGM battery, over here they are 020 size... but I have already discovered that doesn't translate into American, in fact I had trouble finding anyone selling batteries over there full stop |
This is the type of battery that will give you the most power for the longest time, AGM are also called stop start batteries
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
I have a 2nd battery in the right rear side. ______________________________
It's an optima yellow top. ______________________________
Weejock Member Since: 31 Dec 2011 Location: UK Posts: 418 ![]() ![]() |
What extra electronics have you installed that should effect the drain that much that starting is now a problem?
OK, I did this on a L322 and there are some things to watch out for. I won't ask about your electronics - I'll assume your knowledge about wiring them correctly is up to scratch.
