![]() | Home > Technical (L322) > Upper tailgate light switch adjustment |
Spelunker Member Since: 02 May 2016 Location: Nottinghamshire Posts: 248 ![]() ![]() ![]() |
Had a brand new battery drain overnight a few weeks ago. The man from the AA said that it could have been the tailgate not being 'fully' closed leading to the rear compartment interior lights staying on. The car did tell me the tailgate was open, but I only checked it by pulling on the bottom edge - it wasnt loose - rather than opening/closing it. Since then I have made sure to firmly close the tailgate and havent had a problem, but yesterday I inadvertently left the parcel shelf open and noticed that the interior lights were on again. I ended up having to slam the tailgate quite hard - not a good idea! Can anybody help with the location and adjustment of the switch for the rear interior lights? I think it is something to do with the catch, but is it possible to adjust? QUID FACIUM TIBI
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35658 ![]() ![]() |
switch the interior lights 'all' off by pressing and holding the front centre roof interior switch....see if this sort the drain. ... - .- -.
I wasnt aware that the switch at the front controlled the rear luggage compartment (posh word for boot) lights. As long as I make sure I look through the tailgate glass to make sure the light next to the 12v socket is off I assume the tailgate is closed, but it sometimes means slamming it quite hard - not good..... QUID FACIUM TIBI
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
The light switch is part of the lock mechanism and can't be adjusted as such..... but the tailgate does have a 2 stage lock which maybe able to be adjusted so that the upper tailgate doesn't have to be shut so hard to achieve a total lock situation. Might also pay you to leave the parcel shelf open and shut the tailgate a few times... you'll be able to work out how hard it has to be shut to get the lights to go off |
razzer Member Since: 20 Feb 2015 Location: blackpool Posts: 54 ![]() ![]() ![]() |
do you really need a boot light, take the bulb out |
Bluegreygreen Rangie Member Since: 10 Aug 2012 Location: Australia Posts: 53 ![]() ![]() |
This does not sound right at all to me, If you leave the tailgate open the lights all turn themselves off after about 20 minutes anyway, I think this is when the bcm" goes to sleep
Wot Dave says is correct |
Yep got a Vogue - the aa man couldn't find anything draining the battery and i have carried out all of the checks but there is nothing obvious. It only happened the once and i will just keep everything crossed that it doesn't happen again. There is the issue of how hard should it be to 'slam' the tailgate to make the lights go out... QUID FACIUM TIBI
Lukie Member Since: 27 Sep 2016 Location: Liverpool Posts: 433 ![]() ![]() |
not sure if it's a repair you would entertain but will share with all just in case
