Home > In Car Electronics (L322) > Ulf pairing problems
Bobpm45
Hi all, I have repinned and connected my 5th gen Ulf and am getting "activate phone" on my screen . I have installed a momentary button for pairing between 32 and 36 , but no joy when going through the pairing procedure. Should I have a voltage on pin 32 with the ignition on ? I am using the original antenna and cable from the TCU as I believe that should be OK. Bob
Post #406454 26th Sep 2016 10:25am
davidsmith1307
We're not going to tell you after telling us how much you paid Rolling with laughter
Post #406462 26th Sep 2016 11:19am
Bobpm45
And I suppose telling you I sold the subwoofer for £50 and the CD changer for £30 won't help matters either !!
Post #406465 26th Sep 2016 11:34am
davidsmith1307
Neutral Censored
Post #406467 26th Sep 2016 11:52am
Bobpm45
Actually, the ULF in the joblot was fried inside when I tried it ! The one I am trying now I got for £30+postage.I have a feeling something is not right with the pairing wiring as I am getting "activate phone"which I assume is a positive.I definitely have the right wires ( brown/black to earth and white).I have used those blue snap together connectors to splice the pairing button in , but might go to the " choccy block " method for a guaranteed connection.It would help though if I knew if there should be a voltage present on the white wire with the ignition on.Any help gratefully received !
Post #406473 26th Sep 2016 12:00pm
