Home > Technical (L322) > missfire issues |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 |
Could be air in the system. Check fuel lines to and from filter. There's a clear fuel line near the filter, you may see air in this pipe if it is present.
11th Sep 2016 5:54pm |
marcevs72 Member Since: 07 Sep 2015 Location: devon Posts: 16 |
have checked everything now even taking in tank pump out to check filter not partially blocked.everything nice and clean or new.when running i am getting a slight noise from injector area like its blowing past the copper washer on the end of the injector so i checked each one and unplugged each one in turn and when i got to no 4 the noise almost went so in process of getting number 4 out and going to see if blowing past it. |
11th Sep 2016 5:59pm |
Sounds like your problem, let us know how you get on.
11th Sep 2016 6:27pm |
well all back together and did all 6 injectors with new o-rings,washers and now have loads of air coming through the system.after checking everything it seems the in-tank pump is somehow pumping air as well as fuel through.time for new pump !!! |
13th Sep 2016 6:05pm |
Simran0211 Member Since: 10 Jun 2016 Location: Coventry Posts: 299 |
I had the same problem number 6injector was faulty got it refurbished while I was putting back together I noticed that there is a rubber pipe on the right hand side which goes back to the regulator to the sir pipe which over a period of time collapsed in on its self replace the rubber hose put it all back together and it now runs like a dream 👍 |
24th Sep 2016 7:05pm |
Have had all the injectors tested and have 4 that failed and being refurbished now.bloody car lol |
24th Sep 2016 7:09pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Many years ago, I used to occasionally drive a lorry at the Plant Hire company that I worked for, it ran really nice, provided that there was over half a tank of diesel in it...... drop below half and it was a real pig to start, needing to be bled at the side of the road.... After the 5th time of it playing up we were given the go ahead to investigate the problem... turned out to be a rust hole half way up the pickup tube
24th Sep 2016 11:10pm |
All back together and running crap and code reader saying smooth running regulator...I am now stumped as checked/replaced everything |
26th Sep 2016 1:35pm |
The smooth running regulator is not normally the problem check there are two hose pipes you will find that one has collapsed and that will be your problem 👍 |
1st Jan 2017 6:11pm |
D17 JWB Member Since: 29 Aug 2018 Location: Olney Posts: 32 |
Is my L322 Dead?
1st Sep 2018 11:26am |
If I were you I'd talk to Woburn 4x4, they are in Great Brickhill (Milton Keynes but for a couple of miles). They were very helpful and reasonable when sorting out my ffrr TD6.
1st Sep 2018 5:57pm |
Forgot to add diagnostic tools there are only 2 worth having Genuine Land Rover Test Book (don't ask how much, YOU WILL HAVE A CORONARY!!) or the Gap IID tool which is the be all and end all of home diagnostic tools for the Range Rover... I had the BT IID tool which was fantastic as it didn't rely on my pixelated dash display and used my phone instead!
1st Sep 2018 6:08pm |
Thanks miggit, I was about to buy a Bearmach. 2006 L322 3.6 TDV8
1st Sep 2018 6:50pm |
Got the first sign of a fault code.
1st Sep 2018 6:53pm |
