Home > Wheels & Tyres > Wheel nuts and caps |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3813 |
http://www.wrington.co.uk/landrover%20alloy%20wheel%20nuts.html
23rd Sep 2016 10:41am |
themule Member Since: 03 May 2016 Location: Yorkshire Posts: 126 |
Ouch, i might get some stainless hex bar and turn some out on the lathe.
23rd Sep 2016 10:53am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35332 |
the nuts do swell unfortunately but there are cheaper solid type on ebay, about £45 for a set of 20 ...
23rd Sep 2016 11:16am |
Thanks guys. I have abandoned my idea of making a set. Too much effort to make 20 all identical, particularly as they have a taper and stainless can be a pain to machine. Something I might do in the future and machine a custom design on the face.
23rd Sep 2016 11:26am |
Thanks Stan. Saw your post 2 minutes too late I will update profile |
23rd Sep 2016 11:27am |
the standard ones should last a fair while.... ... - .- -.
23rd Sep 2016 11:28am |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1385 |
The foreman at the dealer I used advised against stainless nuts on the grounds that the interaction between the stainless and aluminium in the wheels would cause more corrosion on the wheels, that sounds counter-intuitive but as LR were prepared to replace my swollen nuts under warranty (yes I know, sounds painful) I just went with that. I did find some evidence online to support the stainless/aluminium issue, in the context of construction. I've also replaced the locking nuts with normal ones and instructed the dealer to use only hand tools rather than air on the wheel nuts, both on tyre shop advice. Only Range Rovers since 1988 |
23rd Sep 2016 11:45am |
I got standard nuts, OEM not genuine, from Dan and they seem fine. I didn't buy a set though just replaced the ones that the socket didn't easily fit.
23rd Sep 2016 11:57am |
Just to finish off this thread - I purchased a set of 20 nuts from PowerfulUK (£52) and fitted them all today. Some nuts were very damaged and swollen and I had to really knock the socket on with a hammer. They all came undone ok but I was then left with the socket stuck fast to the nut - this took a lot of effort with the bench vice and a drift to get the socket back. I was very glad I didn't have to change a wheel by the roadside because I don't think it would have been possible - I think the RAC / AA would have struggled too. I cleaned all the stud threads up and put some copper grease on before fitting the new nuts.
30th Sep 2016 10:31pm |
