![]() | Home > Technical (L322) > Air suspension and HDC inactive after fitting track rod ends |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8376 ![]() ![]() ![]() |
If the steering wheel is too far off center it upsets all sorts... I expect it will be fine once the wheel is straight again... |
Mulcher Member Since: 08 Aug 2016 Location: Shropshire Posts: 240 ![]() ![]() ![]() |
Would the steering reset procedure help in this case? This is where after starting the engine (don't drive forwards), you turn the steering wheel to full left lock and then to full right lock. 2006MY 4.2 SC
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
Steering angle sensor will be off possibly due to the tracking being incorrect, get it tracked up then do the go to lock thing.
Just FYI you can drive forward, back, anyway you like, turn left first or right... doesn't make any difference all it wants to see is the end of the lock both ways, and usually clears before that.... I do it reversing off the drive... ![]() I now have permission from the boss to use Y.O.L.O. Enjoy life __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click for Project Fatty off roader- |
As NMJ says, the steering angle is out and it will sort itself out once the tracking is done. Best have all 4 wheels done. |
thanks for clarification oooh, matron :d 2006MY 4.2 SC BMW R1250 GSA Rallye TE Triumph Tiger 1050 (sold) 1979 Pontiac Trans Am (sold) |
Mac1971 Member Since: 17 Jan 2016 Location: Hartlepool Posts: 30 ![]() ![]() ![]() |
Tracking done today , all is good . Many thanks for the replys. Yet another learning curve 👍 |
