Home > Technical (L322) > 4 post lifts, and handbrake adjustment
Embarassed
i blame my meds Embarassed ... - .- -.
Post #405858 22nd Sep 2016 9:01am
Rangeyman
I did not think they could test the handbrake on the mot or even any of the brakes which in itself sounds crazy.My tester puts some gadget in the motor and takes it for a short drive and stamps on the brakes and am certain he does not test the handbrake,just as well as it is crap and I never use it.
Post #405978 23rd Sep 2016 6:53am
berkshirelad
United Kingdom 2007 Range Rover Vogue SE TDV8 Tonga Green
This is because the normal test rig in the garage is set to test 2 wheels at a time - which can't be done with permanent 4x4.
What he (hopefully they) are using is a decelerometer. This is effectively a pendulum attached to an indicator needle that shows the braking efficiency - but only all 4 wheels at once.
It is perfectly possible to test the handbrake using this - remembering that a handbrake is only required to be 16% efficient
I fondly remember the original RR with its transmission brake - apply that on the move and then scrape yourself off the windscreen
Post #406010 23rd Sep 2016 11:36am
miggit
^^ Now your talking....... a proper hand brake that really worked Thumbs Up
My car has been on both 2 and 4 post lifts, and a scissor lift too, my only observation is if your doing anything that involves removing wheels a 2 post is the only safe option..... ffrr's and jacking beams don't see eye to eye Whistle as the chap who did my MOT found out..... new pants please Shocked Yesterday I couldn't spell Engineer... Today I are one!
Post #406025 23rd Sep 2016 12:38pm
Weegie
I was trained not to apply the transmission brake on the move unless in an emergency as it could result in expensive damage to the transmission. John
GAP iiD BT-Sold
Post #406035 23rd Sep 2016 1:12pm
