Home > Technical (L405) > Headlights
mzplcg
Headlights
Quick question for those who might know. I have the standard headlamps, i.e. not adaptive. No cornering lights either.
So, in the below picture I highlighted a part of the light which doesn't actually have a bulb in it. I had thought it was the high beam but it appears to be only a reflector. I checked the AB at Peterborough show as well, the 1/4 of a mil thing, that seems to be the same.
The question, are they all like this or are there headlight options where a bulb gets fitted to this bit?
Thanks
Post #405798 21st Sep 2016 7:33pm
I think that was for the peasant spec DRL bulb �without signature LED DRL�
(like a D4 for example)
Post #405819 21st Sep 2016 10:12pm
mzplcg
Cheers Craig. Thumbs Up
Post #405841 22nd Sep 2016 7:07am
Post #405855 22nd Sep 2016 8:47am
bear100
Peasent spec Rolling with laughter Rolling with laughter 2010 defender utility
2010 RRS TDV8 (gone)
2007 discovery 3 (gone)
2004 discovery 4 (gone)
1994 discovery 1
1970 v8 hybrid (gone)
1975 bobtail (gone)
Post #406552 26th Sep 2016 9:23pm
Rob99
Cam-Tech-Craig wrote:
peasant spec
Is there such a thing with a �75k upwards FF.........surely not..... Shocked Shocked 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #406639 27th Sep 2016 2:05pm
andy2577
United Kingdom 2014 Range Rover Autobiography TDV6 Santorini Black
staying on the subject of headlights .....im looking for an adaptive right hand headlight for a 14 plate vogue but cant find one anywhere with the code "GTG DBL" . does anyone know what other codes are adaptive headlights as im thinking of just buying another adaptive headlight even though the code is slightly different.
cheers 2002 - Blue L322 3.0 TD Vogue (Previous)
2006 - Black L322 4.4 V8 Vogue Autobiography (Previous)
2014 - Black L405 3.0 TDV6 Vogue Autobiography (Present)
Post #408055 7th Oct 2016 6:52am
