Home > Technical (L322) > 4 post lifts, and handbrake adjustment
Brian
I need to change a couple of bushings on the rear (mot failure) and my mechanic has asked is it ok to use the 4 post lift or is there any procedure to watch out for with the suspension "hanging" - I never thought of it before as all I ever had done was a wheel change (and they used a large trolley jack for that) also the handbrake is weak (failed at 15% pass is 16%) I'll do a quick search now but any advice or tips would be welcome
Post #405713 21st Sep 2016 10:26am
craig put my SC up on a four poster without any problems.. ... - .- -.
Post #405714 21st Sep 2016 10:27am
berkshirelad
United Kingdom 2007 Range Rover Vogue SE TDV8 Tonga Green
Re: 4 post lifts, and handbrake adjustment
Unnecessary quote removed
My worry would be that if your mechanic doesn't know that, what else does he not know about maintaining FF
Post #405723 21st Sep 2016 11:47am
zarnd
United Kingdom 2005 Range Rover Vogue SE 4.2 SC V8 Bonatti Grey
Have had mine up on one lots of times Alex
2018 Skoda Kodiaq vRS
2009 Caterham Supersport Race car
2007 M5 Touring
2005 Range Rover Vogue SE Supercharged
2004 SL55 AMG
Post #405727 21st Sep 2016 11:51am
Rob99
Isn't the problem to do with 2-post lifts where they lift the body but leave all 4 wheels hanging in the air? 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #405747 21st Sep 2016 2:30pm
Weegie
Perhaps the OP's mechanic was asking about a 2 post lift? Hence the reference to "the suspension hanging" Question John
GAP iiD BT
Post #405748 21st Sep 2016 2:34pm
Brian
yes sorry I meant a 2 post lift the one that has the 4 arms that go out under the chassis Embarassed
Post #405757 21st Sep 2016 4:00pm
mzplcg
My 07 VSE was put up on a 2 post lift. I drained the air from the suspension completely using the IID tool before it went up so as not to risk popping the airbags. I never had any issues caused by doing this.
Worth remembering that these things can go over cross-axle humps with 2 wheels off the ground, it's designed into them. The shocks have a finite amount of travel and these will stop the wheels hanging down to the point of breaking stuff, they will just get to the end of the shocker's travel and stop.
Post #405763 21st Sep 2016 4:30pm
Mines been on one dozens and dozens of times... when let down it sometimes does some strange things but it's never been a problem, within seconds it's sorted itself out... No need to do any prep.... Thumbs Up
Which rear bushes has it failed on...???? Pete
Post #405774 21st Sep 2016 4:52pm
Big Boy R44ROV
I've had mine on 2 and 4 post ramps with the wheels hanging in the air with no problems at all. They are designed to do that with the ETC when a wheel leaves the ground or cross axles. No problem at all. I wouldn't worry too much about that. Tony
You're always in the Censored ........it's just the depth that varies
2014 L494 5.0 S/C AB Silver
2014 L494 3.0 HSE in Chilli
2014 SL63 AMG White
Gone:
2011 5.0 L322 White (Stolen)
07 4.2 SC in silver.
06 4.2 SC in black RSE
RRS 4.2 SC in Black RSE
52 4.4 Vogue in silver
04 Mercedes CLK 320 Conv
03 4.0 V8 ES Disco in Silver
00 TD5 90 County
98 4.6 HSE in Epsom x3
97 3.9ES Disco
93 L 4.2 LSE in black
too many classics to mention !
Post #405775 21st Sep 2016 5:00pm
Brian
I don't have the fail sheet here but I think it was the near side lower rear hub (or something like that)
Post #405779 21st Sep 2016 5:14pm
If it's lower hub bushes then they will need a very substantial bush puller to do the job, if they are not used to working on big 4x4's they may not realise the ones they have for cars just won't work..
Also probably need new bolts, nuts and washers, they get quite rusty and can snap upon removal... Thumbs Up Pete
Post #405788 21st Sep 2016 6:10pm
Brian
Cheers - I was thinking of telling him to get them anyway Thumbs Up
Post #405792 21st Sep 2016 6:20pm
zarnd
Mine has bee on 2 post ramps as well loads of times.
No issues whatsoever.
cheers Alex
2007 M5 Touring
2004 SL55 AMG
Post #405851 22nd Sep 2016 7:37am
That four poster was a two poster Stan Thumbs Up Bow down Thumbs Up
Post #405852 22nd Sep 2016 7:40am
