![]() | Home > LPG > What a Bargain |
Wylie66 Member Since: 10 Jan 2016 Location: Bushey Posts: 67 ![]() ![]() ![]() |
Well chaps, for the first time in a long while I am planning to keep the FF, if you knew how often i flipped cars after getting bored then you will understand the relevance.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8499 ![]() ![]() ![]() |
If you fit it yourself why do you want it certified...??? Pete
Robert Member Since: 25 Oct 2011 Location: Perigueux Posts: 2290 ![]() ![]() ![]() |
No, it's just a con set up by the LPGA who are an unregulated body, not even insurance companies bother to ask for it these days....
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1364 ![]() ![]() |
some insurers want a cert others don't bother
Amazing, now I understand why the eurotunnel refuses lpg cars. In Holland and in France you need to get a certificat and that is only given after a very thorough check up of the installation by a certified lpg station. Went through it with the RR last year, to get the French reg. It took nearly 3 hours. Every part is checked if it has the certified partnumber etc. Driving on lpg without changing the carte grise (V5) to a lpg V5 can lead to confiscation of the car. |
Ok that answers the certification question, well sort of |
LPG burns 9 degrees hotter than petrol but seeing as they both burn at around 1000 degrees it doesn't make much difference.... |
Yes do duck quacks echo? ![]() What pipe do you use to run from the tank to the front end (guessing cu toff solenoid is first in the line) And the pipe from the filler to the tank has to be sleeved and vented externally, correct? 2003 V8 Vogue in Silver |
Duck quacks do echo just like any other sound, especially if they are LPG ducks and not diesel ducks... |
This is the pipe you need, must use 8mm for fatty...
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
mr_spock Member Since: 07 Apr 2016 Location: Welwyn, Hertfordshire Posts: 311 ![]() ![]() ![]() |
You're welcome to come and examine my (certificated!) BRC LPG installation, take pictures etc. |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1457 ![]() ![]() |
I'd like to see him explain that one to the lease company....... ![]() ![]() 2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black 2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black Last edited by Rob99 on 20th Sep 2016 12:52pm. Edited 1 time in total |
