Home > Maintenance & Mods (L322) > Rear lower arm bushes
Page 3 of 4 <1234>
Well update on this!!
As I've started to do the job I though I'd do the hub upper and lower bushes while I'm there and thought I had them ready to go...
Turns out the upper bushes I just tried to fit are Censored ! They are Britpart(!) and when I test fitted it the thing just slides in with some spare space so it has free movement of the metal sleeve in the hub mount Sad
Going to order up a genuine one ASAP and see if it fits better as it should be a push fit not fit like a stick in a bucket!
I did start to worry the bush puller like fisha's maybe caused it to have widened but then saw sense and realised I wouldn't had been able to pull the thing through the hub as I wanted to make sure I used a unit slightly smaller than the bush itself to draw it out!
Oh the fun!! FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #405482 19th Sep 2016 8:51pm
doclees
United States 2004 Range Rover HSE 4.4 V8 Java Black
Got a picture of those bushings?
Post #405501 19th Sep 2016 11:49pm
Also for a short video but I can't upload that to the forum so will try YouTube now. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #405504 20th Sep 2016 4:28am
YouTube vid
Post #405505 20th Sep 2016 4:31am
Was these the bushes you were looking for Will?
Post #405507 20th Sep 2016 6:33am
Ahh those ones are the the back of the lower rear wishbones John Smile
i may be interested in them though at some point as im thinking i could do an exchange on my lower wishbones to other members with new bushings pushed in, much easier for others then to swap out and save money by being half the price of a new one on an exchange basis :0 FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #405564 20th Sep 2016 2:16pm
Rear lower arm front bushes Will Thumbs Up
Post #405579 20th Sep 2016 3:39pm
doclees
I've never seen a company mismatch a part to the point of play. Sounds like you were given the wrong part or the box was labeled wrong. Does the part have stampings?
Post #405602 20th Sep 2016 5:11pm
Had some moog arms fitted to my skoda by a local garage. So they are available, whether anything for the FF is I'm not too sure, never seen anything. There is nothing that can't be fixed with a hammer😜😜
Post #405626 20th Sep 2016 7:12pm
doclees
Moog everything here in US. Haven't found the entire rear wishbone with bushings though.
Post #405669 21st Sep 2016 1:49am
Dieterf
South Africa 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Mine are also shot.
Diagnosed it myself and pre warned the dealer to have spares available during the scheduled book in service.
Lo and behold, they did NOT diagnose the problem until i showed them!!
Now waiting for the stock, irritating, if i had press tools i would have tackled myself.
Now have to wait 2 days and spend the princly sum of ZAR6000, +/- GBP335/US430
over and above the service
Oh well, peace of mind and all that........
Post #405680 21st Sep 2016 7:14am
Well the genuine unit has arrived and a trial fit has netted unexpected results Sad
It's has much less play than the Britpart item but still has play 😬😬😬
The original item has no play and won't go back in. I tried again as I thought maybe pressing it out had widened the hole but then I realised the only way I could do that is with some super strong press out plate and a 20ton press.
I'm going to see if I can get a part number off the old one but it's just not right and I'm worried the only way is going to be a whole new sodding hub and even worse if I have to do the same to the other side Sad FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #405915 22nd Sep 2016 4:37pm
fisha
Strange it doesn't fit. Nothing daft like a different bush for different versions of the l322 ? Mine was a snug fit that needed pressed in V8 or else ...
Post #405925 22nd Sep 2016 5:56pm
From what I found the only different bush was for armoured ones possibly Sad FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #405931 22nd Sep 2016 6:17pm
doclees
OK not to be a wise a$$ but RAVE says these are specific as to how they go in.
Post #405934 22nd Sep 2016 6:25pm
Page 3 of 4 <1234>
