Home > Technical (L322) > Rear number plate light bulbs....LED or OEM???
Sleeper
United Kingdom 2003 Range Rover HSE 4.4 V8 Adriatic Blue
Thing is i brought some LED ones and they were ok.
But they started flickering....
I do like the LED brighter ones but do not want to chance getting more that do the same
anyone got some and had no issues? or just stick to origional type.
cheers...
Post #405271 18th Sep 2016 7:38pm
Pvw10
United Kingdom 2014 Range Rover Vogue SE SDV8 Firenze Red
I bought from the bay can bus friendly ones almost a year ago without issue, so deffo stick with LEDs and hope yours are just duffers ? Many thanks
Paul
Post #405300 18th Sep 2016 9:45pm
vaz
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
Also got some from ebay, no issues with them.
Can't remember if they were canbus or not.
Steve. 1968 Series IIA Pastel Green, nearly there project
Post #405310 18th Sep 2016 10:31pm
Brian
I bought some LED ones and they worked fine for about 6 months and then I kept getting the "bong" check number plate light so I ditched them and went back to standard. they never flickered as they were canbus but had a habit of rotating around in the holders and as they were single sided (and not like a festoon bulb) that meant constant checking to ensure the light was the right way round. To be honest the light from them (either type) is not great as my car has a reversing camera surround on the number plate so really its not an issue for me Cool
Post #405712 21st Sep 2016 11:21am
holidaychicken
I had eBay can bus ones and worked ok for a while and then started getting multiple light fault bongs but none relating to the number plate lights though.
When I finally decided to check them there was a very strong smell of burning and they had started to overheat but had started to melt the plastic surround which could potentially of caught fire so I have gone back to extra bright standard type as the LED ones do look nice and a massive car blaze is also fairly interesting but altogether an expensive hobby.
Post #405835 22nd Sep 2016 12:20am
