Home > Technical (L322) > Resetting (sync) mirrors
Sleeper
United Kingdom 2003 Range Rover HSE 4.4 V8 Adriatic Blue
How would you go about this
I had to replace both
N/S due to a suicidal pigeon ( looks to have bounced well)
O/S due to a crap body repair shop
Ive disconnected the battery but no joy
so
1 fuse?
2 Double tap button? ( just read this)
John
Post #405074 16th Sep 2016 10:42pm
Double tap usually does it... they sometimes get upset and stop doing anything for a while, just leave them a bit and try again...
It also won't do anything if you drive fast...????
Thumbs Up Pete
Post #405082 16th Sep 2016 11:39pm
Sleeper
cool, will try that and see how it goes
cheers...
Post #405153 17th Sep 2016 6:18pm
Sometimes you have to do it very quick about a million times.....
Usually happens to mine when one gets pushed in off roading, they have a right little dance sometimes...
On a good note they are much stronger than Disco ones... Thumbs Up Thumbs Up Pete
Post #405173 17th Sep 2016 8:13pm
Sleeper
tried it about 5 times so far and then they gave up..think they got fed up of me
so after i got back tried it a few more times and they both go in, then the right one will go out almost straight away.
after about 6 second the left one will go out
ill try it again and again over the course of a few days and see how it goes.
Post #405261 18th Sep 2016 7:05pm
Sleeper
found a thread about the micro switch.
If trying the rest does not work the ill check the micro switch.....but what does it look like ad can you point me to where it is?
Post #405297 18th Sep 2016 9:38pm
