Home > General > Air Con Praise :) |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
Having been away staying in my wooden hut by the sea the week:
22nd Jul 2016 2:11pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35272 |
cool story ... - .- -.
22nd Jul 2016 2:13pm |
cliff5.0sc Member Since: 29 Dec 2015 Location: USA Posts: 137 |
Chill OffRoadRover.com An American Western Range Rover Off Road Blog |
28th Jul 2016 5:36pm |
frikkadel Member Since: 09 Mar 2016 Location: joburg Posts: 56 |
Unnecessary quote removed
16th Sep 2016 12:22pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2032 |
i had a jag, that had working air con. now that's rare! but, if you did that 'turn on the air' at speed, the condensed water, sitting on the evaporator, is then 'frozen off' rapidly, and it used to blow up the screen, and condense, and for a few seconds, it went completly 'white-out' like a cold morning window. PANIC! so, i would advise, to switch on when not moving, or, adjust from hot, slowly. to desired temp. but it looks impressive, like opening a freezer door! |
16th Sep 2016 2:12pm |
IF you get the air con filled with gas right up to the top of the green section on the charging machine it could freeze you nicely. Just don't go above the green or, as I found out, the air con compressor can turn to a block of ice. |
16th Sep 2016 3:26pm |
