Home > Maintenance & Mods (L322) > Reverse/forward sensors |
Realist Member Since: 13 Feb 2016 Location: Wales Posts: 436 |
Little issue here.
16th Sep 2016 9:05am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
If you have a Gen JLR tow bar fitted, plug in some electrics and if the sensors then start working you know its a fault with the rear sensors (as above) if the sensors don’t work with towing electrics plugged in i would start my diagnostics on the front bumper sir...
16th Sep 2016 10:07am |
Thanks both now I have a starting point.
16th Sep 2016 10:34am |
Plugged in my reader and had the following fault show up.
3rd Oct 2016 6:03pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35286 |
the antenna fault is common..i had it on my SC and it all worked ok.. ... - .- -.
3rd Oct 2016 6:18pm |
Thanks Stan. Range Rover quotes.....
17th Oct 2016 4:21pm |
