Home > Technical (L322) > Hard shifting.
umitbat
A Trap 2010 Range Rover HSE TDV8 Atacama Sand
Hard shifting.
Hi
My 03 td6,tranny at 150.000km now,shifts hard from 1 to 2nd at standart 1500-1750rpms.Especially when driving softly with small trottle.
But when changed on sport or manual mode at higher revs it is softer.
Especially after 2100-2200 rpms.
Any ideas?
Should i worry??
Post #404047 8th Sep 2016 1:12pm
I'd get it looked at by a transmission shop, obviously something wrong with it... may get away with just an oil change if you're lucky... There is no adjustment on the box so if that doesn't work they will have to dig deeper, if they know what they are doing they can measure resistance in the valves in the valve block which may indicate an electrical problem...
Good luck Thumbs Up Thumbs Up Pete
Post #404114 8th Sep 2016 9:23pm
umitbat
Thx for response!!
Would setting tyre pressure to 33-36 change shifting manners??
It was really softer but i have to try more tomorrow.
Post #404770 14th Sep 2016 8:30pm
mzplcg
That's doubtful to be honest. The issue is with the transmission. If you catch it in time you might get away with a fluid change as Pete said. Failing that you could get the valve block serviced to see if that improves matters. Beyond that it would likely be a replacement tranny and torque converter.
Post #404795 15th Sep 2016 6:37am
Also worth checking the software is NOT corrupt!
So, i would get a dealer to do a software update first... Then change the fluid & filter Thumbs Up
Post #404802 15th Sep 2016 8:45am
RRPhil
May also be worth having the 2nd clutch accumulator checked out to make sure that the spring hasn’t broken
Phil
Post #404804 15th Sep 2016 9:30am
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Mine had hard shift not long before it toasted altogether, either 1 or 2 broken springs in the accumulater besides quite a few other items including the tc. Best get it checked.
Post #404813 15th Sep 2016 10:26am
umitbat
I tried many times today.
I dont know why but it is way better.
I must try rqualling all maybe but i wont it is better;)
I saw your photo before rrphil great work!!
Post #404839 15th Sep 2016 12:46pm
